BIOS for blind flash Yoga 7 14ACN (82N7) 5800U
  • xiongnemo
    • Apr 2024
    I misconfigured my UEFI settings and it now won't POST. Removing CMOS battery is of no use. I tried to put BIOS.fd in and use Fn + R to blind flash, but also no use. The charging light just flashing amber while ESC and CAPS LOCK turned off and on every 5 or maybe 7 times when charging light flashes. I wonder whether my extraction from Lenovo website suits this occasion and if not, maybe someone of you will have one?
    Many thanks!
    • 22135
    RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
    • xiongnemo
      • Apr 2024
      Sorry for the inconvenience!
      MO: PFNNXB1531076
      S/N: PF2YJWP8 (Chinese Version)
      MB P/N: 5B21C81146
      On the same label with MB P/N: 885B21C81146L1HF15PB0DZ
      '46J SN TXT Code; on MB: 15414038004384511GK1210G HYG40 10D2
      BIOS Chip seems to be 74M12JWSIQ
      • xiongnemo
        • Apr 2024
        In my estimation, the issue should be resolved either with a successful blind flash or resetting the nvram after I manage to get a dump of the original chip.
        • trunguntilyou
          • Aug 2022
          • 367
          • Vietnam
          please i need bios full power status no image
          yoga 7 14ACN6 82N7
          nm-d771
          sn : PF3BCM55
          • peste
            • 13781
            • ROMANIA
            yoga 7 14ACN6 82N7
            nm-d771
            sn : PF3BCM55
            bios extracted from Lenovo website update for Yoga 7-14ACN6
            DMI 5BC000 - 5BDFFF
            • trunguntilyou
              • Aug 2022
              • 367
              • Vietnam
              DMI 5BC000 - 5BDFFF
              Status unchanged ,,, AMD probably has an error
                by Vesko356
                08-11-2023, 03:27 AM
              • to5it0
                by to5it0
                10-24-2025, 01:35 AM
              • HotSaladMan
                Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                by HotSaladMan
                *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                Model : Lenovo ThinkBook 14S Yoga ITL
                S/N : MP28JT19
                MFG Date : 2022/02/09
                Factory ID PRC4
                MO : MPNXB26080FX
                MTM : 20WE001US
                MODULE FCC ID : PD9AX201NG
                IC : 1000M-AX201NG
                BOARD INFO
                FLV34 LA-KO51P
                REV : 1B 2020-08-24
                Bit of Info
                Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                chip id, so i would always uncheck the id check, so it would bypass the error
                i did in fact make...
                11-07-2024, 07:46 AM
              • abhorsen
                Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                by abhorsen
                Hey guys,
                Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                07-06-2023, 10:22 AM
              • TyMercer
                Can I flash a working BIOS from one computer to another of the same make, model, etc?
                by TyMercer
                Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                11-13-2025, 09:39 PM
