Windbond 25Q16JW Flasher
  • TuXiC
    • Jan 2023
    • Austria
    I am trying to flash a Dell G15 5515 but the BIOS chip is a Windbond 25Q16JW and no flasher I tried supports this chip, only fw and Q64 ones.
    Can anyone help me out?
    Thank you very much!
    • 21094
    The chip is 1.8V and 16M-BIT . Thats Mega bits ,not Mega Bytes .The size in Mega Bytes is 2MB .Its the wrong chip, keep looking for the right one.
    https://www.winbond.com/resource-fil...021%20Plus.pdf
    • TuXiC
      • Jan 2023
      • Austria
      So do i understand correctly that this is not the actual BIOS chip?
        SMDFlea commented
        Editing a comment
        No it isn`t.Its the chip for some firmware, thunderbolt or something else.
    • Casr543
      • Oct 2024
      • 5
      • Mexico
      This chip could be the vbios that contain the bios of rtx gpu?
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • donnietr
        Need help id'ing chip on a Dell g15 5515
        by donnietr
        Hello all,
        I have this dell g15 Ryzen Edition 5515. Board GDL56 LA-K453p. It had liquid damage when i bought it. Cleaned it up really well and then used thermal camera to see what got hot.
        Found the power pdw1 and pdw2 under the graphics card were getting hot. Pdw2 was hottest, i had a similiar chip on another board so i put it on this board.
        The other chip is now hot as well, which it was to begin with.
        Thats the problem as i dont know what to call it, like is it a mosfat? or what?
        I will attach a picture of both the boardlabel and of the area with the chips....
        07-18-2025, 08:03 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • BMCappelletti
        Asus Chromebox CN62 - wrong chip put on BIOS reader
        by BMCappelletti
        Long story short:
        - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
        - gave the computer to his son a couple years later
        - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
        - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
        (seems like the story was not that short)
        He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
        01-08-2025, 07:27 PM
