X360 830 G6 BIOS
This topic is closed.
  • mgrharry
    • Sep 2016
    • 211
    • usa
    X360 830 G6 BIOS
    I need to remove a BIOS password on an HP X360 830 G6. I've seen references to the RCUnlocker tool in another thread but I'm not sure which BIOS chip to dump. I only see two Winbond chips, 25Q80DV and 25Q256JVEQ. I assume it's got to be 25Q256JVEQ since the other chip seems too small. Any help would be greatly appreciated. Thank you.
  • Lisa Su
    Badcaps
    • Apr 2021
    • 216
    • Taiwan
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such term
    Thread closed
    • kenkaniff
      HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
      by kenkaniff
      Product Name: HP Pro x360 Fortis 11-inch G9
      System BIOS: U94 Ver.01.08.00 10/06/2023
      Serial Number: 5CG31946F5
      SKU Number: 85W05EC#AK8
      Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
      This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
      I needed to remove bios password...
      10-01-2025, 04:32 AM
    • whelanm87
      ๐Ÿ›  Request: Verified BIOS + EC Dumps for HP Envy x360 15-fe0053dx (JPR50 LA-M794P Rev 1.0)
      by whelanm87
      Iโ€™m working on a non-booting HP Envy x360 2-in-1 laptop and need verified firmware dumps for both the main BIOS and EC chip. Iโ€™ll be posting my own backups for reference and comparison.
      ๐Ÿ” System Details
      • Model: HP Envy x360 15-fe0053dx
      • Product Number: 7HVO3UA#ABA
      • Build ID: 23WW2GQZ6D
      • Motherboard: JPR50 LA-M794P Rev: 1.0 (2023-03-03)
      • Motherboard SPS: N30979-ABA
      • LCD SPS: N49271-601
      • Date Code: 172380
      • Keyboard Type: 0
      • Feature Byte:
        3XeB7kN7.Ba.aqewkwBiBVuhcbdxYPgB
        hZnp.praepq0Md4qkdf
      ๐Ÿ”ง Chip Info
      • Main BIOS chip: Winbond W25Q128JVSQ
      11-16-2025, 05:26 PM
    • macabook
      ๐Ÿ› ๏ธ MSI GP75 Leopard MS-17E71 โ€“ No Display, Deep BIOS/EC Troubleshooting
      by macabook
      Iโ€™m currently working on a dead MSI GP75 Leopard (MS-17E71) motherboard (i7 CPU, NVIDIA GPU) with a no display/no backlight issue initially. After extensive investigation, Iโ€™m at a critical stage involving EC firmware, BIOS/ME region interaction, and possible deep corruption. I'm seeking advanced insight from anyone with experience in EC/BIOS sync issues or PCH-level behavior. Hereโ€™s a full breakdown:
      ๐Ÿงฉ Initial Issue
      07-24-2025, 02:17 PM
    • cr4zychriss
      by cr4zychriss
      • Rebrand: PC Specialist
      11-14-2025, 04:04 PM
    • TopPop
      Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
      by TopPop
      Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
      I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
      12-14-2025, 09:40 PM
