HP 15s-eq1026no BIOS (Serial number, prodID etc)
  • OskarB98
    • Aug 2018
    • 75
    • Sverige
    Can someone help me adding serial number, product name and product ID to this BIOS for a 15s-eq1026no HP laptop?
    Unfortunely I had to flash using the BIOS file I downloaded from HP website, but it's missing all info. I tried BCU but it does not save the info in the BIOS for some reason...
    Serial: 5CD108QRHS
    ProdID: 1K1S7EA#UUW
    Model: 15S-EQ1026NO
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Serial: 5CD108QRHS
    ProdID: 1K1S7EA#UUW
    Model: 15S-EQ1026NO
    Upload your original bios backup even if it's corrupted . DMI area must be transferred from it to the virgin bios.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • OskarB98
      • Aug 2018
      • 75
      • Sverige
      I don't have it sadly! :-(
      I had given up on this board so I deleted the file, only to realise the issue was something else a month later...
      It does boot with this BIOS. but no information in BIOS...
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        In this case you should try re-entering the data using a suitable version of BCU or NBDmiFit, or you can use a DMI region from another similar machine to get rid of the annoying missing data messages at every boot - I guess this is your main problem and therefore you want to find some solution, right?​
        • OskarB98
          • Aug 2018
          • 75
          • Sverige
          It does not give me that message after I did update using BCU, but none of the information is still visible in the BIOS/System Information
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • jackkyxu
            HP 15-eu1026nr BIOS (Serial number, prodID etc)
            by jackkyxu
            Can someone help me adding serial number, product name and product ID to this BIOS for a 15-eu1026nr HP laptop?
            Serial: 8CG2205LDR
            ProdID: 67W66UA#ABA
            Model: ​ 15-eu1026nr...
            04-17-2025, 11:00 AM
          • Friend33
            Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
            by Friend33
            I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
            06-16-2024, 03:13 PM
          • acerRI
            Gigabyte MB missing serial number in BIOS
            by acerRI
            We have in company to custom PCs with Gigabyte B760 GAMING X (1.0). When i export hwhash for enrolling PC in azure, i got computer name as MMDEFAULTSTRING.
            PCs wiht this name are not compliant with company policy, number should be MMDxxxxxx (xxxxxx is serial number of mb).
            I have found that is possible to embbed in BIOS serial number so when i exporting, it will get proper computer name.
            Does anyone have know if somehow do that, maybe with some hexeditor, because i have found that some specialized tools are needed.
            Any help will be...
            09-23-2025, 05:26 AM
          • TecnicaNTT
            Lenovo Thinkbook 16P G2 ACH - BIOS Serial number missing
            by TecnicaNTT
            I got a Lenovo Thinkbook 16P G2 ACH on the bench with a botched BIOS (somehow my client blanked it). I restored the laptop and got it up and running with original BIOS from Lenovo Support website.
            My problem is now that the machine details are missing in the BIOS (Serial Number, MTM, etc.)
            I tried to write the details with the Lenovo Uone Tool but had now luck. It is giving me an error: "ERROR: Locate protocol with LenovoEeprom, Status=[e]. EEPROM fail when reading or writing data."
            I am now asking here for help if anyone knows how to do this in...
            09-20-2024, 08:10 AM
