hp mini 110 bios flash reset
  • welhim
    • Feb 2013
    • 40
    • philippines
    hello...please help me reset my bios password on my hp mini 110...
    error code after 3 attempts 2MC93608F0...THANKS and Godbless ..
    done..
    removed CMOS bat and short
    removed bios IC
    but nothing happens..please hellp ...
  • are-red
    • Feb 2013
    • 24
    • malaysia
    Re: hp mini 110 bios flash reset
    Friends look here https://www.badcaps.net/forum/showthread.php?t=26981
    • Rockhd
      • Mar 2015
      are-red
      might this post you made still be active ? I use the url and it tells me I have no access. But friends use this was your header. Im trying to be friendly!
      Trying to learn this board , Havn't BBS ed in 15 years. Not much time to spend. here , Still a bench tech working most days repairing broken electronics. Look me up when you need help with tough troubles! I would like to achieve a good reputation here at Bad Caps.
      Look forward to your reply.
      Rockhd
      • trebo
        • 514
        • Wales, UK
        Strange I am unable to access the Link as well,
        for some reason It says that I don't have permission to access the page
        • reinforce
          • Mar 2013
          • 10
          • Austria
          yea, me too as the bulletin message below:
          "reinforce, you do not have permission to access this page. This could be due to one of several reasons:
          Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
          Your account must be activated. Have you activated your account by clicking the link in the email that was sent to you when you created the account?
          If you're a new member, have you read the welcome PM outlining how to create your first new thread? "
            by Vesko356
            08-11-2023, 03:27 AM
          • llek100
            HP EliteDesk 800 G4 35W DM Desktop Mini PC - not posting after BIOS reset attempt
            by llek100
            Hello, sorry for the long post, I just wanted to include any details that might help.
            A bit of backstory - I currently have 5 of these MiniPCs - I got them for very cheap from Ebay. All of these PCs are BIOS administrator password locked without their drives.
            I also got a G3 large tower, that I could reset the password of fine just using a header and a button on the motherboard.
            So I thought that I could do the same with the G4 MiniPCs, oh how wrong I was.
            First of all, I stumbled upon a tutorial, that apparently showed a BIOS password reset procedure - where I basically...
            09-18-2024, 09:15 AM
          • AkaBukai
            Is it okay to flash stock bios onto the motherboard's BIOS?
            by AkaBukai
            Hi there,
            I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
            The little LED on the power button is flashing slowly and nothing happen.
            This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
            So I decided to flash the BIOS using a cheap programmer.
            And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
            I also...
            12-19-2024, 12:15 PM
          • YG007
            Asus BIOS How To Reset To Default Settings?
            by YG007
            Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
            I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
            06-05-2023, 08:22 PM
          • James Jackson
            Panasonic CF-20G0247VM BIOS Bad Flash Help
            by James Jackson
            I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
            Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
            05-01-2025, 11:28 AM
