Dell Latitude e5580 LA-E091P Rev: 2.0 (A01)
  • czacha414
    • Mar 2023
    • 21
    • poland
    • Dell Latitude e5580
    • SN: D01JGH2
    • MB: CDM80 LA-E091P Rev: 2.0 (A01)
    • SPI: 25B128CSIG
    I had problem with this laptop that in post it was giving TPM is missing warning. There was no TPM option in BIOS, I`ve tried all Windows/BIOS methods with no luck. I tried to downgrade BIOS thru Windows but Dell have disabled this option so I came up with the idea changing SPI firmware by programmer.
    I`m using CH341 one, I`v started with the software that was provided with the programmer. It was reading my chip as:
    • 25/26 SPI Flash
    • Gigadevice
    • GD25Q128
    I`ve made a backup (file attached as 1.bin) but it was giving error:
    chip main memory with the contect are in disagreement
    Then I`ve found badcaps thread saying about need to mod my CH341 to have 3.3 line on 28th pin so I`ve done that. Now my software doesn`t detect IC anymore (when clicking detect it gaves error: accress violation at ….).
    Using Neoprogrammer it is finding my IC as GIGADEVICE SPI 25XX Flash, i can choose between GD25Q127C/GD25Q128B/GD25Q128C. It is reading my IC but shows only few first lines with some data and the rest is FF. I cant erase or programm IC, it is starting but never ending (hang?).
    My concern is neoprogrammer shows on the picture bit different IC legs pinout than it appears on my programmer ( see pictuire 2, 3 and 4).
    Any help apprectiated.
  • Markus1741
    • Sep 2020
    • 843
    • N/A
    Re: Dell Latitude e5580 LA-E091P Rev: 2.0 (A01)
    • SN: D01JGH2
    • SPI: 25B128CSIG
    • 25/26 SPI Flash
    • Gigadevice
    • GD25Q128
    Hello, first of all, undo the modification to your CH341A and watch this video.
    Why should the manufacturer deliver this CH341A like this only to have it modified.
    If you watch the video you will understand why modification is unnecessary.
    They tested it that way too.
    https://www.youtube.com/watch?v=J8-Sh7DjiXw
    The second, your original BIOS file, is damaged and cannot work, more on that later.
    • hoaca388
      Badcaps
      • Jan 2022
      • 11707
      • SN: D01JGH2
      • SPI: 25B128CSIG
      • 25/26 SPI Flash
      • Gigadevice
      • GD25Q128
      Latitude 5580
      Service Tag: D01JGH2
      • Markus1741
        • Sep 2020
        • 843
        • N/A
        • SN: D01JGH2
        • SPI: 25B128CSIG
        • 25/26 SPI Flash
        • Gigadevice
        • GD25Q128
        So now for the second part, your BIOS on the left and a BIOS on the right that is intact.
        You see all the messages in yours that shouldn't be like that.
        Good luck ...
        • czacha414
          • Mar 2023
          • 21
          • poland
          Thanks, will undo programmer mod and get back here.
          • czacha414
            • Mar 2023
            • 21
            • poland
            Thanks! What is the difference between these two files?
            Originally posted by hoaca388
            Latitude 5580
            • czacha414
              • Mar 2023
              • 21
              • poland
              You`re right - I`ve undo my programmer mod and now I`m able to erase IC. Great!
              • czacha414
                • Mar 2023
                • 21
                • poland
                OK, I`ve tried the second file and laptop is working again. GREAT! But I still have post allert saying `tpm device is not detected`.I`vee read that downgrading of bios might help with that. Any experience with that matter?
                Latitude 5580
                • czacha414
                  • Mar 2023
                  • 21
                  • poland
                  I`ve found several threads on badcaps saying that it can be fixed by downgrading older version of bios. Does anyone have one?
                  • Markus1741
                    • Sep 2020
                    • 843
                    • N/A
                    My uploaded file is 1.13.0 is this old enough ....
                    Tread #4
                    • qayyum786
                      • Aug 2018
                      • 1933
                      • INDIA
                      try this one on factory mode
                      Recommended by dell
                      • czacha414
                        • Mar 2023
                        • 21
                        • poland
                        I can confirm - with that one `TPM is missing` warning is gone, I even updated BIOS to newest one and still no warning. Thank you!
                        Recommended by dell
                        • czacha414
                          • Mar 2023
                          • 21
                          • poland
                          Thank you Markus, you`re the one who helped me the most as my programmer was not working properly.
                          Tread #4
                          • florenz
                            • Apr 2018
                            • 43
                            • Cameroon
                            Recommended by dell
                            THX U
