HP zbook power g8 bios pass
  • Sanad_Ali
    • Sep 2023
    • 3
    • Libya
    Any friend can help me to unlock ho ZBook power g8 bios password
    • 20339
    Re: HP zbook power g8 bios pass
    You MUST:
    Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
    • mytagz
      • Nov 2022
      • 12
      • Bulgaria
      Hello.
      Can anyone please, help me remove bios admin password on a laptop HP Zbook Power G8 with i7 11800H and Quadro T600
      I try with RCUnlocker v1 - but say: Wrong Chip
      Also try wiht HPUnlocker v1 - but after that - there's no post on display, fans don't spin, and there's no power.
      SN: 5CD2284BB4
        SMDFlea commented
        Editing a comment
        If it says wrong chip it means theres another chip, 16MB or 32MB .It will probably be on the other side of the board
    • hoaca388
      Badcaps
      • Jan 2022
      • 11226
      • Viet Nam
      Originally posted by mytagz
      Hello.
      SN: 5CD2284BB4
      ZZZ
      • mytagz
        • Nov 2022
        • 12
        • Bulgaria
        Originally posted by hoaca388
        ZZZ
        With this bios, the laptop does not start. The fans are not spinning. The charging light blinks 10 times and does not work.
        The laptop has two bios chips. Both have the same inscriptions, there is no chip on the other side of the bottom.
        Do both chips need to be rewritten?​
        • mytagz
          • Nov 2022
          • 12
          • Bulgaria
          Can someone help please? I see in another thread a successfully removed password from G9
            • 20339
            Post the other chip
            • mytagz
              • Nov 2022
              • 12
              • Bulgaria
              This is bin form the 2nd chip.
              RCUnlocker also say its wrong chip.
              • hoaca388
                Badcaps
                • Jan 2022
                • 11226
                • Viet Nam
                AAA
                • mytagz
                  • Nov 2022
                  • 12
                  • Bulgaria
                  AAA
                  With this bios - Caps lock and num lock blinks 7 times
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11226
                    • Viet Nam
                    Check hardware.
                    • alfredposadas09
                      • Aug 2020
                      • 343
                      • Philippines
                      7 white blinks bios failure double check if you solder it back properly
                      • Quin TeknoLife
                        • Mar 2024
                        • 21
                        • the Netherlands
                        I'm having same problem on an elitebook 850 G8. I'm pretty sure the solder job isn't good, I cannot seem to keep the chip in place and the pads being minimal (as opposed to the pads of the other BIOS chip) and the chip being legless aren't helping. I always seem to blow the chip off-center or the chip doesn't seem level causing some of the pads to not make contact. Any tips keeping the chip to stay on the spot it should be? superglue or heat resistant tape?
                          SMDFlea commented
                          Editing a comment
                          Tweazers. Never use glue
