Hi i need help, im looking for bios of alienware GDR51 LA-K741P plss :c
alienware la-k741p
Tags: None
Re: alienware la-k741p
dump okAttached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Name your thread with model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password.
Do NOT post "clean me", "clear bios", "clean bios", "bios need" or other such terms
.Comment
I need help, this computer failed in the update, it froze, it already has no image on the screen
main model: GDR51 LA K741P Rev 1.0 (A00)
reg model: P87FAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
If this file does not work, you should look for hardware problems.Attached Filesif you find these attachements useful please consider making a small donation to the site
The same thing happens with the file. The strange thing is that the computer did not complete the bios update correctly and now the image does not appear. I still leave a copy of all the chips that the computer has and can someone help me?
The device now turns on, it restarts like this several times, then it stays on and the power LED flashes.Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
Hi all, I have an Alienware M17 R4 (P45E) with motherboard LA-K741P (GDR51) and it turns on but displays nothing on the screen. The power button doesn't show any error codes, just RGB lighting.
I'm hoping that a new BIOS might be a step towards fixing it, so I've attached the dumped BIOS file here. I can't tell if it's corrupt or not, so I'm hoping it can be rebuilt. Thanks!
Service Tag: 5M3T0J3
EX: 12220560111Attached Filesif you find these attachements useful please consider making a small donation to the site
tryHi all, I have an Alienware M17 R4 (P45E) with motherboard LA-K741P (GDR51) and it turns on but displays nothing on the screen. The power button doesn't show any error codes, just RGB lighting.
by druxHi,
I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
These models have AMI/Aptio BIOS.
Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...-
11-03-2024, 01:18 AM -
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by SCREAM76Alienware m18 R2 i9 cpu no screen 5 blue 3 red blink
I added the original bios. I need a clean me or a new working bios.
Alienware m18 R2
Servis tag: 4SWZH54
Serial: 10455585160...-
11-01-2025, 08:32 AM -
- Loading...
