Dell G7 17 7790 bios needed
    • 20367
    Re: Dell G7 17 7790 bios needed
    Originally posted by piaggi
    I have the tpm problem. I have flashed with factory bios, saved the service tag, but always have tpm alert.
    Tried older bios, same. I don't have the original bios...
    What is the procedure to solve this problem?
    And wich is the tpm chip on this board?
    Thanks!
    Post the service tag -> https://www.badcaps.net/forum/showthread.php?t=103570
    • qayyum786
      • Aug 2018
      • 1933
      • INDIA
      Thanks!
      POST YOUR SERVICE TAG AND BIOS FILE WITH ERROR
      All donations to badcaps are welcome,see the donate button at the bottom of the page,or click on this link to donate via PayPal. Every donation made will go towards server fees and maintenance costs.
      • piaggi
        • Nov 2019
        • 11
        • Hungary
        Thanks for the quick help!
        service tag: FZK0JX2
        • piaggi
          • Nov 2019
          • 11
          • Hungary
          I tried the two bios from post #11. I think better if ignore my attached bios dump. Both are better than mine, because with mine i have to manually restart the notebook after second restart, and showing rtc battery error by leds.
          But the tpm error is present in all three...
          • piaggi
            • Nov 2019
            • 11
            • Hungary
            Can somebody help me?
            • hoaca388
              Badcaps
              • Jan 2022
              • 11265
              • Viet Nam
              #26
              Dell G7 17 7790
              Service Tag: FZK0JX2
              • piaggi
                • Nov 2019
                • 11
                • Hungary
                #27
                Originally posted by hoaca388
                Dell G7 17 7790
                You are my hero! Thank You very much! Works perfectly!
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • Loli Popu
                  DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                  by Loli Popu
                  Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                  12-13-2024, 03:28 AM
                • Aarush653
                  Dell Latitude 5340 corrupt bios - clean bios needed
                  by Aarush653
                  Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
                  Worked good before failed flash now won't power at all.
                  May have been a bad connection.
                  Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
                  32mb chip - 25Q256JVEN
                  Attach Dell Bios Update file v1.14 - original Dell update...
                  10-14-2024, 04:28 PM
                • bmxlovah
                  Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                  by bmxlovah
                  My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                  11-24-2022, 06:29 AM
                • trix11
                  Dell Precision T1650 MT Workstation bricked after BIOS update
                  by trix11
                  I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                  - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                  - Dell Precision T1650 mid tower Workstation
                  - Xeon E3-1225 V2
                  - 32Gb PC3-12800E RAM
                  - 4Tb SATA HDD
                  - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                  I see now that others have experienced like issues e.g.:
                  - https://www.dell.com/community/Prec...
                  10-24-2022, 10:35 PM
