help me unlock HP Pro x360 435 G9.
  • qth2010com
    • Jan 2022
    • 6
    • UAE
    unlock file help me.please!
  • volinakis
    • Jan 2021
    • 2734
    • N/A
    Re: help me unlock HP Pro x360 435 G9.
    write only chipset containing "PROBOOK x360 435 G9 CHINH.BIN" dump and put back the other one as is. At 1st boot press F10 and reset bios to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the bottom cover. Or extract DMI from your bios dump:
    Feature Byte: 476J6S6b7B7J7M7R7W7m7saBaQapaqauawbVcAd6dpdqeMeTfPguk8mEmVn7nWpFpqqjqz.N3 (no spaces)
    Serial: 5CG23846C4
    SKU: 6K584PA#ABG
    Built ID: 22WWPXAT601#SABG#DABG
    Board CT: PPZLK00WBH52LR
    Name: HP Pro x360 435 G9
    Save and use BCU to exit MPM mode or restart laptop how many times counter shows.
    • qth2010com
      • Jan 2022
      • 6
      • UAE
      Serial: 5CG23846C4
      SKU: 6K584PA#ABG
      Thanks so many Bro.This file working.
      • SuborQ
        • Aug 2017
        • 19
        • Украина
        Help me get DMI information, HP Pro x360 435 g9 with password, SN: 5CG3216GHC, and tell me how to do this, and did I correct main correctly?
        • qayyum786
          • Aug 2018
          • 1933
          • INDIA
          Serial NUMBER :- 5CG3216GHC
          SKU :- 5Z1M2ES
          CTNumber:- 6MEST0DTZHQ2DF
          Build Id:- 22WWPXBT602#SABU#DABU
          Feartube byte:- 476J6S6b7B7J7M7R7W7m7saBaQapaqauawbVbhcAdpdqeTfPgu k8mEn7nWpFpqqjqz.fM
          • volinakis
            volinakis commented
            Editing a comment
            or he can look at the label inside back cover ...
          • SuborQ
            SuborQ commented
            Editing a comment
            Thank you very much, I know about the stickers, but I would like to learn how to get dmi with a dump, do you get it manually or using a program? Hex did not find the information, is it encrypted?
        • SuborQ
          • Aug 2017
          • 19
          • Украина
          SKU :- 5Z1M2ES
          For some reason I couldn’t remove the password, can you help? There are 2 files here, my own and one edited by me.Tell me where I made a mistake?
          • SuborQ
            • Aug 2017
            • 19
            • Украина
            5CG3216GHC
            • hoaca388
              Badcaps
              • Jan 2022
              • 11809
              5CG3216GHC
              Unlocked
              • SuborQ
                • Aug 2017
                • 19
                • Украина
                Originally posted by hoaca388
                Unlocked
                Thank you very much
                • IMLJ
                  • Jan 2015
                  • 25
                  HP PROBOOK 435 G10 Bios unlock
                  SN:5CG3343FTQ
                  Thanks.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11809
                    SN:5CG3343FTQ
                    Thanks.
                    This is a topic for HP Pro x360 435 G9​ , not G10
                    • IMLJ
                      • Jan 2015
                      • 25
                      okay thanks, i will create a new topic then.
                      • mtherana
                        • 117
                        • South Africa
                        please help
                        HP Pro x360 435 G9
                        S\N : 5CG3120BS8
                        Its completely blank with caps lock blinking after trying to flash the bios I was trying to remove Absolute software
                        below is the 32MB file from the chip i tried flashing I didn't touch the other chip.
                        please help.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11809
                          Originally posted by mtherana
                          please help
                          HP Pro x360 435 G9
                          S\N : 5CG3120BS8
                          please help.
                          Read chip again, backup fault
                          • mtherana
                            • 117
                            • South Africa
                            its already erased in the process of trying to flash it with one of the files in this thread ..😭
                            • mtherana
                              • 117
                              • South Africa
                              is there any other way?
                              • mtherana
                                • 117
                                • South Africa
                                Here is another Dump can someone please help.
                                • mtherana
                                  • 117
                                  • South Africa
                                  Here is the file from the Second chip U365 also 32Mb
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11809
                                    Have you noticed, #13 and #17 give us 2 different files (2.05 MB and 150.8KB), which proves that the chip reading software has a problem.Additionally, post the product number.
                                    • mtherana
                                      • 117
                                      • South Africa
                                      I think both of the files at post #13 and #17 are damaged and didn't read properly for backup ... I posted them thinking maybe someone can fix one of them, my apologies if they are unfixable and just taking up space.
                                      Here is the full laptop info:
                                      HP Pro x360 435 G9
                                      Prod id: 7N084ES#ACQ
                                      SN: 5CG3120BS8
                                      BUILD ID : 22WWPXBZ601#SACQ#DACQ
                                      Feature Byte: 6J6S6b7B7J7M7R7W7maBapaqarauawbVbhcAfPgujXk8mEn7nWpFpnpqprqjqz.n4
                                      thank you
                                        HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) Specification for Upgrade or Repair
                                        This specification for the HP ProBook x360 Pro x360 Fortis 11 inch G9 Notebook PC Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pro x360 Fortis 11 inch G9 Notebook PC boardview and Pro x360 Fortis 11 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                        09-07-2024, 05:50 AM
                                        HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) 14 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion x360 Pavilion x360 - 14-dh1000na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion x360 - 14-dh1000na boardview and Pavilion x360 - 14-dh1000na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                        09-06-2024, 03:30 PM
                                        HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
                                        This specification for the HP ENVY x360 ENVY x360 - 15-dr1011na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 - 15-dr1011na boardview and ENVY x360 - 15-dr1011na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                        09-06-2024, 12:18 PM
