Hp elitebook 840 g9
  • mehar
    replied
    It's the same old problem. The laptop draws over 600mA for 2 seconds, and the fan spins. After that, the load remains at 85mA. I need to explore a different direction.
    Thanks a lot for responding to both of you
  • Zibbo
    replied
    Originally posted by mehar
    Need Help to Clear ME this file
    Model: HP EliteBook 840 G9
    Motherboard Number: 6050A3417601-MB-A01
    S/N:5CG3026830
    Old file Attached
    IC Location: U367
    Bios Ver: U71 Ver. 01.13.00
    What I have done until now:
    I downloaded and replaced the same version of the bios region but to no avail.
    I tried to open it with intel mfit 16.1 but giving multiple errors.
    Try
  • volinakis
    replied
    S/N:5CG3026830
    Old file Attached
    IC Location: U367
    upload original bios, not one with BIOS_region replaced.
  • mehar
    replied
    S/N:5CG3026830
    Old file Attached
    IC Location: U367
  • usuario0217
    replied
    Hello team,
    Can some one help me unlock this bios many thanks
    S/N: 5CG4094YZQ
    PRODID: 7K7T0LP#ABM
    HP ELITEBOOL 840 G9
  • rex98
    replied
    Originally posted by Tosebeee
    good dey boss i have 840 g9 with bios password pls help clear the bios sn 5CG2371FSB MAIN AND EC FILE ATTACHED
    read my post # 221 https://www.badcaps.net/forum/troubl...27#post3576427
  • Tosebeee
    replied
  • szabi
    replied
    Hi everyone
    can someone help me with unlocking the Hp 840 G9 bios
    SN:5CG3080ZYF. THANK YOU IN ADVANCE​
  • abomochris
    replied
    please unlock bios hp elitebook 840 g9. SN : 5CG2248Z1L
  • qayyum786
    replied
    Originally posted by zzduczz
    Please unlock bios elitebook 840 g9
    SN:5CG32464T6
    write from post #220 new version is blocked by HP
  • shiriff47
    replied
    Originally posted by rex98
    i noticed there's a lot of unlock request for this model HP EliteBook 840 14 inch G9 and patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should flash both.
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU.
    Thank you very much it's working great the password is gone.
    i did like you said but i did't use BCU i just flash back my original bios
  • rex98
    replied
    use BCU.
  • Bios Cracker
    replied
    Originally posted by NERI
    How about friends, I have this bios from an HP elitebook 840 g9, the problem is that it doesn't give me an image, it just spins the fan quickly, thank you in advance.
    SN:5CG2351ZR6
    PRUDUCT ID: 6D763LT
    HP ELITEBOOK 840 G9
    Pls Check and reply.
  • krogs214
    replied
    Hi anyone can help
    clear this bios
    Hp Elitebook 840 g9
    Sn: 5CG3311710
    Board number: 6050a3417601
    thank in advance
  • djesoric
    replied
    Originally posted by TauroX
    Hello It turned out like this for me. At the first boot, reset to factory settings. In the second case, reset the security settings to factory defaults.
    i tried this bios and the suggested procedures but still asking for password when i reset the security settings to factory default.
  • BGinvestments
    replied
    Originally posted by BGinvestments
    Hi, could someone help me unlock this file? I tried it myself but when I enter mpm mode it asks me for the password to restore the default security settings
    S/N. 5CG4091ZY2
    I solved it on my own, it turns out that version u71 01.11.05 or higher retains the password, I have downgraded the version to u71 01.10.00 using an ec, and a clean bios, it works perfectly, you just have to write the dmi information later with some mpm tool.
    Here I leave you an ec and a clean bios of that version.
    PD. Make sure your actual bios is U71 too
  • TauroX
    replied
    Originally posted by djesoric
    Somebody please help me remove password on my hp elitebook 840 g9. thank you so much in advance.
    Model: HP ELITEBOOK 840 G9
    SN: 5CG3451B30
    prodID: 6W5L9UC#UUF
  • djesoric
    replied
    SN: 5CG3451B30
    prodID: 6W5L9UC#UUF
  • dihcar84
    replied
    Originally posted by dihcar84
    hi,please help unlock
    840 G9
    SN:5CG40114QY
    anybody can help please
  • NERI
    replied
    Originally posted by shiyab
    hi try
    It could not be done since the serial number configuration is missing. Since it is configured with the same one, only the region changes.
