Asus Tuf fx706hcb bios password remove pls
    Originally posted by joshAU View Post
    Can someone tell me what the password is from this BIN file?
    Model number is Asus FX706H.
    Serial number is NANRCXARR012423.
    Printed on the mainboard is DANJJMB1AA0 REV A.
    The file was read with a CH341A black programmer using the NeoProgrammer 2.2.0.10 software and then zipped so it could be uploaded.
    The chip did not detect correctly, but it seems to have been read and verifies OK after setting it as a W25Q128JV.
    The correct model on the chip itself is 25R128JV.
    Any help greatly appreciated, and a merry Christmas to all.
    try
      Try
        Boot Password : SSS777
        hi try
          Thank you, noname2024 and minhdigital for the modified BIN files.
          Thank you also shiyab for the actual password!
          I will try the password first when I am back in front of the PC next Monday and update.
          If not, I will remove the BIOS chip and reflash it with one of the above two BIN files.
          Thank you all, once again, much appreciated, and a merry Christmas to all!
            Just a quick update....
            Thanks again shiyab.
            The password you provided worked!
            Much appreciated
            Do you have to decode or decrypt the password from the bin file, or run it through an algorithm?
            I know, a long time ago, the IBM Thinkpad BIOSes used to store their admin passwords as MF1 scancode, but I am not familiar with more recent ones.
            Anyway, thanks again.
              Hi Folks,can i ask for a bios cleaning or inspection?,laptop starting but no capslock,no fan spinning.Thanks in advance.
              Laptop is:
              ASUS TUF FX706HC-HX007W
              SN: MBNRCX06H683487
              CN: DDH5 24M
              MotherBoard: DANJJMB1AA0 Rev:A
                Laptop is:
                SN: MBNRCX06H683487
                CN: DDH5 24M
                hi try
                  Originally posted by shiyab View Post
                  hi try
                  I tried it,doing the same,the chipset might be dead,but i have no short anywhere,all voltages present,but not at CPU.Current is 7-17mA on standby.I think its not bios.I have to investigate further,thank you.I return if need further help on bios,i might need to change PCH or EC.
                    FX706HCB-HX152W SN:N1NRCX05P86703G
                    it died while updating the bios,the file seems corrupt
                      this is not the chip. something with 128 aka W25Q128
                        that's not bios chipset , see pic. Read it without ISP when you choose chipset in RT809
                          Thanks, it seems like the file is corrupt or I didn't quite understand it.
                            hi try
                              Thank you, everything is fine and working normally
