acer ex2519 model no. N15W4 need bios
  • sanjiv16
    • Jul 2013
    • 52
    • philippines
    goodmorning guys
    please help me i have acer ex2519 model no. N15W4
    board id:HSB J MV-4 94V-0 E89382
    need good working bios file. it's only turning on with blue led light but no display thank you
  • qayyum786
    • Aug 2018
    • 1959
    • INDIA
    Re: acer ex2519 model no. N15W4 need bios
    Originally posted by sanjiv16
    goodmorning guys
    please help me i have acer ex2519 model no. N15w4
    board id:hsb j mv-4 94v-0 e89382
    need good working bios file. It's only turning on with blue led light but no display thank you
    post yor bios backup
    • sanjiv16
      • Jul 2013
      • 52
      • philippines
      Heres my back up bios file
      • qayyum786
        • Aug 2018
        • 1959
        • INDIA
        serial number :- NXEFASP02585002A776600
        here is the new bios + serial number and windows key injected
        • sanjiv16
          • Jul 2013
          • 52
          • philippines
          THANK YOU SO MUCH BRO IT'S WORKING 100%
          • Partyza
            • Mar 2023
            • Ukraine
            qayyum786, thank you. Working bios.
            • lucky dave corpuz
              • Sep 2024
              • Philippines
              PLs help me i need bios for extensa 2519 n15w4 Motherboard: HSB J MV-4 94V-0 E89382
              This is my Back Up Thank You
                • 22289
                You MUST:
                • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                • lucky dave corpuz
                  • Sep 2024
                  • Philippines
                  You MUST:
                  Heres my SNID 74200271366 , S/N no. NXEFASP00274200A996600
                  Model NO.N15W4, EX2519-C49F Series,
                  Board Model No.( Dominno_BA MB 142851-1 448 05302 0011 ) (HSB J MV-4 94V-0 E89382)
                  THANK YOU!
                  • EbrahimSiami
                    Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                    by EbrahimSiami
                    I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                    **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                    **What I have tried so far:**
                    1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                    07-02-2025, 02:31 PM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • Neggo
                    BIOS BIN for Acer Aspire 3 A315-41-R8TH (Model no. N17C4)
                    by Neggo
                    Hi heveryone!
                    I'm here to ask you guys about a problem I've been having with a laptop I just recieved. I came to the conclusion that the BIOS might be bricked.
                    Initially the PC did turn on, the fan span for a second, the blue light was on, then the screen was barely noticeable while turning on and off, so after searching online on local and other forums I found some other people having the same issue and saying it was a bricked BIOS. I have no idea what caused it because I recieved this device in a non funcioning state.
                    I will attach the bin file I was able to exctract
                    02-05-2025, 06:33 PM
                  • TyMercer
                    Can I flash a working BIOS from one computer to another of the same make, model, etc?
                    by TyMercer
                    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                    11-13-2025, 09:39 PM
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    11-14-2025, 04:04 PM
