HP Pavilion Gaming 15-dk1425f (GPC52 LA-J641P REV1.0) bios request
  • mouez_by
    • Sep 2013
    • 14
    I have an HP Pavilion Gaming 15-dk1425f laptop. When I start it up, it displays a CMOS error and then hangs.
    I have tried changing the RAM and checking all components on my GPC52 LA-J641P REV1.0 motherboard, and everything seems to be okay.
    I backed up my BIOS and cleaned ME, but there was no change.
    I also tried flashing multiple BIOS dumps found on this forum, but the same problem persists.
    Therefore, I am attaching my BIOS and asking if someone could help me build or repair the BIOS region. Thank you.
    Last edited by Vesko356; 05-15-2023, 11:27 AM. Reason: "HP Pavilion Gaming 15-dk1425f (GPC52 LA-J641P REV1.0)" to the thread title.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Corrupted bios HP
    Originally posted by mouez_by
    I have an HP Pavilion Gaming 15-dk1425f laptop...
    Virgin dump for this machine with your DMI and Windows key added. Next time add serial number in your request, and much more informative thread title (I'll edit the title, because "Corrupted bios HP" is ...well, let's say at least poor.):
    Become a Badcaps supporter
    Thanks to all supporters.
    • mouez_by
      • Sep 2013
      • 14
      Re: HP Pavilion Gaming 15-dk1425f (GPC52 LA-J641P REV1.0) bios request
      Thank you for your help, and I will pay attention next time whencreate a new thread with more details, but still not working, same problem,display freezes immediately with multiple lines are involved.
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Doesn't sound promising, I'm afraid your issues are not bios related. Try with this dump too, if the problem persist search for a hardware fault:
        • mouez_by
          • Sep 2013
          • 14
          Thank you for providing this file, but unfortunately, it still doesn't work.
          After checking the system board with the schematic LA-J643P, which I found to be similar to LA-J641P, I assume that the problem is coming from the PCH . All the voltages are present, but it appears to be overheating. However, when I discharge the system board for 24 hours and then start it again, it shows a CMOS error. Subsequently, it hangs and stops displaying anything.
          • almussafer
            • Jun 2019
            • 87
            • Iraq
            try this bios file ok 10%
            • almussafer
              • Jun 2019
              • 87
              • Iraq
              try this file ok 100000000%
              • Bloodhoundje
                by Bloodhoundje
                03-16-2024, 03:12 PM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • cr4zychriss
                by cr4zychriss
                • Rebrand: PC Specialist
                11-14-2025, 04:04 PM
              • sssssssssssssss
                Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                by sssssssssssssss
                I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                Symptoms:
                • Laptop powers on but no display at all (completely black screen)
                • Caps Lock blinks twice with a pause, then repeats continuously
                • F12 LED stays on permanently
                • No POST, no boot sequence, nothing on screen
                Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                What I've tried:
                • Hardware reset (battery removal, power
                09-04-2025, 06:45 AM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
