Dell precision 7560 bios and ec dump needed
  • electronica
    • Apr 2014
    • 89
    • algeria
    #61
    Hi friends, I have a Dell Precision 7560 that came for unlock, so when I unlocked it, I put back the bios chip, but the laptop didn't come on. I realized that the chip is dead (gd25q256), so I replaced it with Winbond 25q256. Now the laptop come on with this error 6 white 3 amber
    I tested many bios in this forum, but none worked. Same error: 3*6
    dell model: precision 7560
    ST: DQJD6G3
    old bios attached
    thank you​
    • Markus1741
      • Sep 2020
      • 994
      • N/A
      #62
      ST: DQJD6G3
      old bios attached
      thank you​
      Try this. Me clean file from your original bios. I don't think it helps, but maybe.
      Press the power button for more than 25 seconds to reset RTC.
      Disconnect all power sources (AC, battery, coin cell) and discharge any remaining power by pressing and holding the power button for 3 to 5 seconds to ensure all power has been discharged.
      • electronica
        • Apr 2014
        • 89
        • algeria
        #63
        Thank you for your help. I programmed your bios, but the same problem.
        3*6
        • minhdigital
          • Nov 2022
          • 766
          • Vietnam
          #64
          ST: DQJD6G3
          old bios attached
          thank you​
          Send tou you, try
          • electronica
            • Apr 2014
            • 89
            • algeria
            #65
            Same thing, thank you.
            Please, if someone has a clear HD picture around the bios area, maybe there is a missing resistance; unfortunately, a schematic and board view are not available.
            • Markus1741
              • Sep 2020
              • 994
              • N/A
              #66
              Hello try a new one ...
              • ZoOLf
                • Mar 2021
                • 61
                • NA
                #67
                hello,
                so i have this dell 7560 which don't turn on, all voltages are present but there is this orange led only when Power button is pressed when released its off, could be a damaged bios?
                ST: J3R7LN3
                • ZoOLf
                  • Mar 2021
                  • 61
                  • NA
                  #68
                  Originally posted by ZoOLf
                  hello,
                  ST: J3R7LN3
                  I flashed one of the bios listed here, it gives 3*6 code. any suggested solution?
                  also it cycle the screen test mode with all colors
                  • Markus1741
                    • Sep 2020
                    • 994
                    • N/A
                    #69
                    hello,
                    ST: J3R7LN3
                    Hello, try removing the WWAN and the WLAN card and starting them without both.
                    • ZoOLf
                      • Mar 2021
                      • 61
                      • NA
                      #70
                      Already tested without wwan, the wlan is soldered,
                      anyway i tested one of the bios present in this forum but got the 3*6 error.
                      Thx
                      • qayyum786
                        • Aug 2018
                        • 1959
                        • INDIA
                        #71
                        try
                        • electronica
                          • Apr 2014
                          • 89
                          • algeria
                          #72
                          qayyum786
                          Thank you; you're the best man.
                          My laptop has two issues: the BIOS chip and the BIOS file.
                          I used winbond 25q256 instead of GD 25R256, and they are not compatible.
                          So I found the exact BIOS chip and your dump, and the job is done.
                          Laptop come alive.
                          Thank you all for your help.
                          • qayyum786
                            • Aug 2018
                            • 1959
                            • INDIA
                            #73
                            Laptop come alive.
                            That sound is musical to my ear
                            • ZoOLf
                              • Mar 2021
                              • 61
                              • NA
                              #74
                              Can i use the same .bin or its specific for his laptop?
                              i have 3*6 error and screen test loop with colors
                              • electronica
                                • Apr 2014
                                • 89
                                • algeria
                                #75
                                its your bin file test it .
                                • electronica
                                  • Apr 2014
                                  • 89
                                  • algeria
                                  #76
                                  • qayyum786
                                    • Aug 2018
                                    • 1959
                                    • INDIA
                                    #77
                                    Yes any one can yous the posted bios in the particular model its a NEW BUILD, FACTORY MODE, UNLOCKED so no any DMI, no any WINDOWS KEY
                                    • ZoOLf
                                      • Mar 2021
                                      • 61
                                      • NA
                                      #78
                                      dont work give that amber led when power button is pressed,
                                      my ic is 25R256 not Q can this be the problem?
                                      • ZoOLf
                                        • Mar 2021
                                        • 61
                                        • NA
                                        #79
                                        Now the eeprom is totally dead, its no more detected by the ch341a
                                        that sucks
                                        • qayyum786
                                          • Aug 2018
                                          • 1959
                                          • INDIA
                                          #80
                                          that sucks
                                          Read post #72
                                            DELL Precision 7560 Mobile workstation 7000 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 7560 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7560 boardview and 7560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Precision...
                                            09-07-2024, 03:40 AM
