HP 840 G5 clean me please
by SMDFleaJust a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
the infamous **"Endpoint Security" error message.
Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
The offsets and file sizes are part of the naming convention i`ve used for the extracted
files.
hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
filling everything after...-
Channel: BIOS Requests ONLY!
by yucel-yucelI need Monster Tulpar V20.3 Clean Me Bios.
The srkma chip was replaced, I tried to do a clean me but I didn't get any results, it opens late.
Can you do a clean me for my original bios, thank you.
GM5TG0O222100999
MNS220330000307...-
04-21-2025, 07:12 AM -
by piernovLaptop model: Thomson THN14B
Board model: C116C VB1
Working BIOS
Clean TXE (2.0.0.2077, original: 2.0.0.2075)
Clean NVRAM
Windows key offset: 0x415014 (set to "ABCDE-FGHIJ-KLMNO-PQRST-UVWXY", change before flashing)
PS: problem was partial short on PS7516 5V boost converter (near the 2R2 inductor) which causes symptoms that look like no POST problem....-
11-11-2024, 11:49 AM -
by tom3kLaptop: Dell Precision 5540
MB: LA-H331P Rev: 1.0(A00)
Hi.
I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
After extracting my BIOS in FIT the ME Region size is 7565 KB.
However the ME Region files I fouud online are 11688 KB in size.
Can someone help me find he correct clean ME Region?
Thanks!
Code:╟─────────────────────────────┬───────────────╢ ║ Family │ CSE ME ║ ╟─────────────────────────────┼───────────────╢
by c.danielHi guys; i have this mainboard, and i have some problems with her:
1. it shutdown randomly
2. if i let her shutdown and out of power supply, the next morning will power on only after i made an bios reset from jumper
I do all the changes, cpu, ram, power supply, i even update bios from 1.20 to 1.30, then to 1.40 and last, to 1.50, wich is the last bios vs from asus. I clean with izopropilic alcool all contacts from cpu, ram, sata, pci express. Mainboard is very clean. No pin from cpu socket is bent.
After is power on, it's working perfect, sound, lan, all are...-
- Loading...
