Lenovo IdeaPad Gaming 3 15ARH7/15ARH7D/16ARH7/16ARH7D BIOS
  • bushmann
    • Feb 2014
    • 147
    • Slovakia
    If anyone needs the BIOS for this model, I will attach it.
    It is an exported BIOS image from the factory update.
    BIOS works normally.
  • 78pinFPC
    • Nov 2024
    • 3
    • US
    Thanks for providing this!
    Would this work at all for the HLG50 LA-M082P as well?
    I'm having an issue where it's not booting up and all the BIOS for it that i can find online are on forums with sketchy paywalls...
      • 21040
      Post your backup, full laptop model and serial number.
      • 78pinFPC
        • Nov 2024
        • 3
        • US
        Thank you for your quick response!
        - The full model (I believe) is:
        HLG50 LA-M082P
        Rev: 1A
        2022-01-21
        - What do you mean backup?
        - The serial number I have been searching for for an hour. The sticker on the bottom must've fallen off because it's not there, can't use any of the ways that requires it to boot obviously, and I don't have access to the original box or receipt, and I have completely removed the board and scoured everything, with the exception of pealing off the thin aluminum shielding covering most of the back as it doesn't seem to readhere well....
        The closest thing I did find that could be of use, next to the model number in smaller type on the motherboard is:
        E__:1AQ3
        HLG50 D01
        451AUG38L01
        (and then the MAC address)
        Last edited by 78pinFPC; 02-21-2025, 12:03 PM. Reason: *edited formatting for clarification
        • peste
          • Dec 2016
          • 12887
          • ROMANIA
          you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
          • nikosystem
            • Feb 2015
            • 15
            • colombia
            hi can you rebuild this file tk
            lenovo ideapad gaming 3 15ARH7
            sn. MP299GQ3
            HLG50 LA-M082P
            • peste
              • Dec 2016
              • 12887
              • ROMANIA
              sn. MP299GQ3
              HLG50 LA-M082P
              bios extracted from Lenovo website update for BIOS Update for IdeaPad Gaming 3 15ARH7, IdeaPad Gaming 3 16ARH7
              DMI 1F82000 - 1F84000
              • ingenieroedu
                • May 2023
                • 70
                • Colombia
                Hello everyone, this laptop has the following problem: when it tries to start the operating system, it restarts. The same happens when trying to install any operating system. It normally lets you browse when entering the BIOS. I've looked for any power consumption problems on the motherboard, but I haven't found any. Now all that's left is to test the BIOS. Any help? I appreciate it.
                Lenovo IdeaPad Gaming 3 15ARH7 - Type 82SB
                Motherboard: HLG50 LA-M082P rev. 1A
                Serial number: MP299GQ3​
                  • 21040
                  Did you see the extracted bios at post 7 .Just copy your DMI from your backup and put it into the virgin bios using the offsets 1F82000 - 1F84000
                  • ingenieroedu
                    • May 2023
                    • 70
                    • Colombia
                    Thanks bro, I'll do it with this file like this.
                    • phix888
                      • Feb 2013
                      • 3
                      • Russia
                      Hi. Have same problem, but new BIOS is not help. Do yo resoleve your problem?
                      • ingenieroedu
                        • May 2023
                        • 70
                        • Colombia
                        Hi colleague, it turned out to be a problem on the board, a fault in the PQB1 mosfet and then another fault in the MP2845AGQK controller.
                        • phix888
                          • Feb 2013
                          • 3
                          • Russia
                          Thanks for the answer. In my case, the problem was in a faulty DMI unit, which I transplanted into a clean dump. Flashing a clean dump without DMI solved the problem.
                          • Yela
                            • Jul 2025
                            • 4
                            Motherboard HLG50 LA-M082P
                            2022
                            Ryzen 7 6000 Series
                            BIOS Chip
                            : W25Q128JV – 128 Mbit (16 MB)
                            No display
                            Fan spins for about 10 seconds, then stops
                            Can someone help repair BIOS?
                              • 21040
                              2022
                              Ryzen 7 6000 Series
                              BIOS Chip
                              No display
                              Wrong backup, that`s the NVIDIA vBios firmware. Are you sure the part number is W25Q128JV, the vBios is usually on a 2MB chip.
                              • Yela
                                • Jul 2025
                                • 4
                                Are you refering to this one?
                                  • 21040
                                  That`s the vBios. The W25Q128JV file you posted above is the 2MB vBios written 8 times to make the file 16MB. So, someone has wriiten the 2MB vBios to the W25Q128JV chip or you chose the chip yourself (reading the W25Q16DW as W25Q128JV) in the programmer and it`s read it 8 times.
                                  • Yela
                                    • Jul 2025
                                    • 4
                                    Yes seems like I am mistaken this is W25Q16JWSSIQ W25Q16JWSSIQ
                                    and I got the wrong chipset, this is the nvidia gpu... I now found the BIOS
                                    • Yela
                                      • Jul 2025
                                      • 4
                                      sorry i just got a new programer my programmer was making a problem. now i got the file correctly readed, if you can take a look at this i would appriciate it!
                                      • phix888
                                        • Feb 2013
                                        • 3
                                        • Russia
                                        UPD! In my case, the problem was not in the BIOS at all. When I soldered the BIOS chip, the processor standing next to it heated up and the laptop started. After cooling down, the defect appeared again. The problem was in the processor failure due to the black compound.
                                          Lenovo IdeaPad Gaming 3 15ARH7 Notebook G Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad Gaming 3 15ARH7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 15ARH7 boardview and Gaming 3 15ARH7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 06:38 AM
                                          09-07-2024, 06:31 AM
                                        • Chrisjacob
                                          Request for PW removed Bios - Lenovo IdeaPad Gaming 3 15ARH7
                                          by Chrisjacob
                                          I am writing to request your assistance to provide an edited bios without password on my Lenovo IdeaPad Gaming 3 15ARH7 laptop:
                                          Serial Number:MP2BKH42
                                          Machine Type Model:82SB0001US
                                          I am able to get into bios but not update any of the settings with password I have. So I'm assuming I need to reflash with unlocked bios. I can read bios chip withch341a programmer and get bios file off of computer. I also have updated bios file from manufacturer. Just not sure how to edit it to remove password.
                                          Appreciate any help in unlocking...
                                          09-20-2023, 06:29 AM
