Dell Inspiron 15 3511 Bios Needed
  • urad29
    • Dec 2021
    • 11
    I have a Dell Inspiron 15 3511 (Service tag: FY3C9T3) which is not booting past the Dell logo and I cannot enter the BIOS by pressing F2.
    I therefore believe that the BIOS is corrupted.
    I have spent some time trying to figure it all out as I have managed to reprogram BIOS's in the past.
    The motherboard has two chips, one is a 25Q64JVSIQ and the other is a 25Q128JVSQ.
    Firstly, how do I know which one is the BIOS, or are they both BIOS (have only worked on single BIOS boards).
    Secondly, I cannot seem to get a bin file or the like from the BIOS exe file.
    I would be extremely grateful if someone could shed some light on this.
    Many thanks,
    Uri
    • 20932
    Re: Dell Inspiron 15 3511 Bios Needed
    Many thanks,
    Uri
    The bios is split accross both those chips, post them both .There are different methods to unpack dell bios updates.Most of the time you won`t get a full image only an update.If it is a corrupt bios and not some other hardware issue,then the corruption could be in either of the bios chips, the 1st with the flash descriptor,Gbe region and ME firmware,or the bios region in the 2nd chip.
    • urad29
      • Dec 2021
      • 11
      Thank you SMDFlea for a prompt response!
      How would I go about, either correcting the corrupted BIOS or reflashing the BIOS?
      I have tried using numerous methods to get a bin file which makes sense size wise, out of the exe but with no luck, probably because, as you say, this is an update and not a clean install.
      Also, would the fact that it is booting to the Dell logo hint to the corruption being in either the first chip or the second one?
      Many thanks for taking from your time for this.
        • 20932
        post your backups and someone will help
        • urad29
          • Dec 2021
          • 11
          Sorry for the delay in getting back to you.
          As I said above, there is an 8MB chip and a 16MB chip. I have attached what I extracted off the 8MB chip and all seems to be fine. However, the 16MB chip is not detedcted with my reader and when I manually select it and read the contents, all I get are FFFFFFFFF's as if the chip is empty.
          Please advise on how you would proceed.
          Thank you very much
            • 20932
            Thank you very much
            What model is your programmer and software version.Are you using a sop8 clip or a WSON8 pogo adapter. Have you desoldered the chips ? ,what type of adapter are you using.Are both chips SOP8 or only one,the other WSON8 ,or both WSON8
            • urad29
              • Dec 2021
              • 11
              I am using the CH341A programmer and using Asprogrammer 2.1.0.13.
              I tried again to plug in the chip and this time the program was able to identify the chip and read from it. I have attached it below.
              Many thanks.
              • rex98
                • Feb 2023
                • 1278
                • Mandaue CEBU, Philippines
                Dell Inspiron 15-3511 i3 bios please
                can someone help me on my Dell Inspiron 15-3511 GDM50 LA-L241P REV 1.0 (a00) it doesn't boot up no fan spin, 3.3v and 5v are present when i press the power button the cpu heats up.
                processor is i3
                i attached my bios main and EC i hope someone would help me fix my bios dump.
                • hardware1
                  • Sep 2021
                  • 2930
                  • N/A
                  Re: Dell Inspiron 15-3511 i3 bios please
                  processor is i3
                  Write your Device Service Tag.
                  all donations are welcome,
                  • rex98
                    • Feb 2023
                    • 1278
                    HERE IT IS thank you. FQLQMJ3
                    • hardware1
                      • Sep 2021
                      • 2930
                      • N/A
                      Here's your New BIOS file, try it and let me know.
                      • rex98
                        • Feb 2023
                        • 1278
                        here's your new bios file, try it and let me know.
                        thank you but it still doesnt work, i checked the isl95522 pmic it only gives 9v i would try replacing it.
                        • VIEN
                          • Aug 2023
                          • 5
                          • vietnam
                          processor is i3
                          • VIEN
                            • Aug 2023
                            • 5
                            • vietnam
                            Dell 3511 GDM50 LA-L241P REV 1.0 cleaar me tes ok
                            • jags46
                              • Mar 2022
                              • 11
                              • República Dominicana
                              Hi, I have a dell inspiron 15 3511 with mdm Mobile Device Management. Could someone help bios bin files here
                                • 20932
                                Originally posted by jags46
                                Hi, I have a dell inspiron 15 3511 with mdm Mobile Device Management. Could someone help me clean my bios bin files to remove this?
                                Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                                • jags46
                                  • Mar 2022
                                  • 11
                                  thank
                                  • RyanRiz
                                    • Apr 2016
                                    • 15
                                    • Malaysia
                                    Test working CleanME
                                    Dell Inspiron 3511
                                      DELL Inspiron 3511 Notebook 3000 Specification for Upgrade or Repair
                                      This specification for the DELL Inspiron 3511 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3511 boardview and 3511 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 3511...
                                      09-07-2024, 06:38 AM
                                      09-07-2024, 06:21 AM
                                      09-07-2024, 03:40 AM
