dump ideapad 3-15ITL6
  • vtx86
    Hackerman
    • Feb 2025
    • 10
    • brazil
    #61
    Originally posted by peste
    you have everything you need at post #14...
    I am having trouble to program the 16MB (128) chip, every time I get this error when verifying.
    I am programim the chip directly on the board ( is not un solded).
    • peste
      • Dec 2016
      • 13924
      • ROMANIA
      #62
      The bios chip must be unsoldered from the board before writing or reading..
      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
      solder wires between the programmer and the bios chip..​
      • vtx86
        Hackerman
        • Feb 2025
        • 10
        • brazil
        #63
        I have sucessfully writen the 64bits chip 8MB, but the 128bits 16MB gives the error.
        I am using the CH314a with the clip (image attached), isn't this the same as soldering wires to the programmer?
        I was reading that this may happen because of a 3.3V and 5V bug with this programmer.
        Now I have sucessfully written the 16MB using NeoProgrammer, but my notebook is still with 12 flashes on LED and turn off with no video.
        Can you show an image of how can I solder wires between programmer and bios? I am afraid of unsoldering and not been able to solder again, I can solder big wires but this are too small for my solding iron.
        • 3liMohmammad
          • Jan 2023
          • 47
          • Lattakia
          #64
          Originally posted by SMDFlea
          Everything you need is at post 14.
          use the HxD program (you can find it for free)...enter both bios in the program (of the laptop, and the virgin one from the website), select the interval from post #14, where the DMI interval is passed and (COPY-PASTE) from the bios- the laptop, in virgin bios... and that's it..
          pleas
          did you mean to select from offset 422000 to offset 423fff from bios 16mb on post 14 and copy and replace it in my backup bios
          and then i have new file 16mb and the 8mb with no edit from post 14
          this is what i do
          • ALRAHI
            • Nov 2020
            • 14
            • dubai
            #65
            nm-d472 rev 2.0 m2 ssd cant detect pls help
              • 22293
              post S/N Service Tag or SNID, full name and mode etc.
              • ALRAHI
                • Nov 2020
                • 14
                • dubai
                #67
                ideapad 3-15ITL6 Laptop - Type 82H8
                serial number
                PF4EM42S
                Device Type Model
                82H803SHAX
                • peste
                  • Dec 2016
                  • 13924
                  • ROMANIA
                  #68
                  serial number
                  PF4EM42S
                  Device Type Model
                  82H803SHAX
                  • NERI
                    • Jun 2016
                    • 20
                    • slp
                    #69
                    I have a Lenovo IdeaPad 3 15.11B, but only the power LED is blinking. Can someone help me? I already tried post 14.
                    s/n: pf3pwlc5
                    motherboard: hs460 hs560 hs760 nm-d471 rev:2
                    • Robert-360
                      • Jul 2017
                      • 9
                      • Ecuador
                      #70
                      CLEARME PLEASE
                      IT TAKES ME 13 SECONDS TO GIVE ME THE VIDEO
                      LENOVO 14ITL6
                      SN/ PF491YQE
                      • osman68i
                        • May 2015
                        • 358
                        • The Netherlands
                        #71
                        Originally posted by Robert-360
                        CLEARME PLEASE
                        LENOVO 14ITL6
                        SN/ PF491YQE
                        try post Hoaca
                        https://www.badcaps.net/filedata/fetch?id=3568921
                        • Robert-360
                          • Jul 2017
                          • 9
                          • Ecuador
                          #72
                          Originally posted by osman68i
                          SAME PROBLEM
                          I GET VIDEO IN 20 SECONDS
                          • peste
                            • Dec 2016
                            • 13924
                            • ROMANIA
                            #73
                            SAME PROBLEM
                            https://www.badcaps.net/forum/troubl...l6#post3299726
                            • Yassine Shabou
                              • May 2024
                              • 10
                              • TUNISIA
                              #74
                              I have a Lenovo IdeaPad 3-15ITL6, Serial Number: PF49R4JL, that shows 12 short beeps when powered on, which seems to be a BIOS problem.
                              After disassembling the motherboard, I noticed it has two BIOS chips:
                              • One XMC QH128AHIG (16MB)
                              • One GigaDevice GD25B64 (8MB)
                              I’m looking for the original BIOS dump files (BIN) for both chips, if available.
                              I can reprogram the chips manually with a CH341A or SOFI SP8.
                              Any help would be greatly appreciated!
                              Thanks in advance!
                                SMDFlea commented
                                Editing a comment
                                thread merged. Everything you need is at post 14, make a backup first before flashing any other bios.
                            • asliyucegsm
                              • Jun 2011
                              • 351
                              • Turkiye
                              #75
                              Hello friends,
                              On this motherboard, there is a broken connection between the RAM slot and the CPU.
                              However, it works fine with onboard RAM only — everything runs well.
                              The problem is: when I shut down Windows, the screen goes black but the system keeps running.
                              I have to power it off manually using the on/off button.
                              When I turn it back on, it works normally again.
                              I’ve tried many BIOS files from forums and other sources, but only the original BIOS works correctly.
                              I would like to thank in advance any friend who can help me patch or edit my BIOS to solve this issue.
                              🗂️ Original BIOS dump files are attached below.
                              Model Info:
                              • HS460 / HS560 / HS760 — NM-D471 Rev.2.0
                              • IDEAPAD 3 16ITL6
                              • MO: PF9XB2C17133
                              • MTM: 62H803AVTX
                              • 25Q64 (8MB) + XM25QH128AHIG (16MB)
                                thank you
                              • peste
                                peste commented
                                Editing a comment
                                post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                              • 22293
                              Type the laptop serial number S/N: ??????????
                              • asliyucegsm
                                • Jun 2011
                                • 351
                                • Turkiye
                                #77
                                S/N:PF49VL3M
                                • peste
                                  • Dec 2016
                                  • 13924
                                  • ROMANIA
                                  #78
                                  Originally posted by asliyucegsm
                                  S/N:PF49VL3M
                                  • asliyucegsm
                                    • Jun 2011
                                    • 351
                                    • Turkiye
                                    #79
                                    Hello SMDFlea, can you change my bios? I can't run it with another bios, is that possible?
                                    from page 14 the problem is not fixed, same
                                      • 22293
                                      GGCN54WW virgin bios + DMI.
                                        Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                        09-07-2024, 05:20 AM
                                        Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook 3 Specification for Upgrade or Repair
                                        This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 05:00 AM
