dump ideapad 3-15ITL6
  • peste
    • 12582
    • ROMANIA
    #41
    Originally posted by Mihir
    I do not understand how the copy and paste works in the HxD program, I tried it yesterday but how do I make sure that the new bios has all of the dmi that it needs how do I compare, because I tried to find serial number even on my old bios dump but I could not find it, the rest of that is clear
    you can't find it because it's encrypted..copy the interval I told you from your bios to the virgin bios..that's all you have to do..right click on the interval in your bios (copy), right click on the same interval in the virgin bios (paste) and that's it..
    • Mihir
      • Jul 2021
      • 6
      • India
      #42
      Okay buddy, thank you very much 😊
      • Lionel Rodríguez
        • Dec 2024
        • Eeuu
        #43
        Hola necesito poder deshabilitar ram de un Ideapad 3 15itl6, leí por ahí que se puede deshabilitar desde el mismo archivo BIOS.bin que corresponda y volver a flashear mediante USB, es correcto eso? Si es así podrían ayudarme con ese archivo este es un Ideapad 3 15itl6 type 82h8, gracias
        Hi, I need to be able to disable RAM on an Ideapad 3 15itl6. I read somewhere that it can be disabled from the same BIOS.bin file that corresponds and re-flash via USB. Is that correct? If so, could you help me with that file? This is an Ideapad 3 15itl6 type 82h8. Thanks.
        in English please..
        • peste
          • 12582
          • ROMANIA
          #44
          in English please..
          post S/N,motherboard model, post the original contents of the bios chip..,etc.
          you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
          • mandirinet
            • Mar 2018
            • 13
            • timika
            #45
            Lenovo Ideapad 3 14ITL6 Bios Needed
            Bios Issue ... When I turn on the Laptop .. Its only flashing the power led 12th times
            I try flashing with files on post 14 stil no change..
            Laptop Lenovo Ideapad 3 14ITL6
            Board Number: HS460 HS560 HS760 NM-D471 Rev:2.0
            S.N: PF495NBY
            MTM: 82H701J0ID
            Here is My old bios backup​
            • hoaca388
              Badcaps
              • Jan 2022
              • 11605
              #46
              S.N: PF495NBY
              MTM: 82H701J0ID
              ideapad 3-14ITL6 Laptop - Type 82H7
              • mandirinet
                • Mar 2018
                • 13
                • timika
                #47
                Thank you for reply,but still blink 12 times..maybe hardware failure.
                • andrestecno
                  • Jul 2022
                  • 24
                  • Argentina
                  #48
                  Did you find any solution?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11605
                    #49
                    Check hardware.
                    • 3liMohmammad
                      • Jan 2023
                      • 34
                      • Lattakia
                      #50
                      i need bios too
                      lenovo ideapad 15itl6
                      HS460 HS560 NM - D472 REV : 2.0
                      BGA RAM
                      MO : PF9XB3526112
                      MTM : 82H803JCAX
                      SN : PF4GJ4SL
                      My Backup uploaded
                        • 20633
                        Originally posted by 3liMohmammad
                        i need bios too
                        BGA RAM
                        MO : PF9XB3526112
                        MTM : 82H803JCAX
                        SN : PF4GJ4SL
                        My Backup uploaded
                        Everything you need is at post 14.
                        use the HxD program (you can find it for free)...enter both bios in the program (of the laptop, and the virgin one from the website), select the interval from post #14, where the DMI interval is passed and (COPY-PASTE) from the bios- the laptop, in virgin bios... and that's it..
                        • 3liMohmammad
                          • Jan 2023
                          • 34
                          • Lattakia
                          #52
                          thank you
                          I will try it
                          • 3liMohmammad
                            • Jan 2023
                            • 34
                            • Lattakia
                            #53
                            i am sorry but it is not work with me
                            • 3liMohmammad
                              • Jan 2023
                              • 34
                              • Lattakia
                              #54
                              i need bios too
                              BGA RAM
                              MO : PF9XB3526112
                              MTM : 82H803JCAX
                              SN : PF4GJ4SL
                              My Backup uploaded
                              any help pleas ?
                              • peste
                                • 12582
                                • ROMANIA
                                #55
                                any help pleas ?
                                if it doesn't work, either you wrote the bios with errors or the laptop has another problem...
                                • 3liMohmammad
                                  • Jan 2023
                                  • 34
                                  • Lattakia
                                  #56
                                  edit the bios 16 mb in post 14 and writ th new one and writ the 8b bios from post 14 but the same problem the amp on power supply is 0.069 and power light is flashing
                                  and the all volteg in s5 is ok except slp_s5 and slp_s3
                                  so i think the problem is bios
                                  • vtx86
                                    Hackerman
                                    • Feb 2025
                                    • 10
                                    • brazil
                                    #57
                                    Hello! My notebook has a blinking power light and no video, I believe its a Bios issue.
                                    I need the bios for Lenovo IdeaPad 3 15ITL6 SN: PE0ACWX9.
                                    I have downloaded the Bios file from the lenovo website, but after converting to .bin there is only one bios file with 25MB, and I need 2 bios files so I can write with my CH341A writer on both bios.
                                    Thank you very much, I need it to work, If someone can help me fix I can donate.
                                    • peste
                                      peste commented
                                      Editing a comment
                                      post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                                  • peste
                                    • 12582
                                    • ROMANIA
                                    #58
                                    post the contents of the bios chip even if it is corrupted..
                                    • vtx86
                                      Hackerman
                                      • Feb 2025
                                      • 10
                                      • brazil
                                      #59
                                      Updated thank you!
                                      • peste
                                        • 12582
                                        • ROMANIA
                                        #60
                                        Updated thank you!
                                        you have everything you need at post #14...
                                          Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-07-2024, 05:20 AM
                                          Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
