hp elite x2 1012 g2 tablet wrong bios
  • darckreign1984
    • 260
    • Romania
    i attach ec rom and bios that start the tablet after flash then after mismatch message - request a reboot confirm, then only led blink white yellow
    "the bios ha recovered its identity data from embedded controller..."
    confirm ok
    then tablet dont show nothing on screen
    Last edited by darckreign1984; 02-22-2023, 09:28 AM. Reason: processor its sr342, and i atach on post 3 the bin find near cpu (seem that this motherboard have 3 winbond flash memory on )
  • hoaca388
    Badcaps
    • Jan 2022
    • 11643
    Re: hp elite x2 1012 g2 tablet wrong bios
    confirm ok
    HP Elite x2 1012 G2 Base Model Tablet
    • darckreign1984
      • 260
      • Romania
      i atached all info that i find. in first post.
      prodid 1LW05EA#ABD
      what do you mean base model?
      • darckreign1984
        • 260
        • Romania
        I tested last posted bios.
        Did not work
        Some blink and I believe it a bootloop, and nothing on screen.
        Fan in this bootloop it's try to start and rotate 5 degree.
        • hoaca388
          Badcaps
          • Jan 2022
          • 11643
          Did not work
          Press OK until the counter goes from 49 to 0
          • darckreign1984
            • 260
            • Romania
            ok on touch screen?
            if i press enter laptop restart - and did not start again screen
            if i press escape same response.
            if i flash bios provided from you i describe symptoms a post before
            • darckreign1984
              • 260
              • Romania
              the picture atached its for the bios posted in first post.
              the bios posted from you did not show nothing on screen
              • darckreign1984
                • 260
                • Romania
                i press ok - now with a mouse - the tablet show hp logo like 5 seconds, then restarted, and same simptom, like a bootloop, and nothing on screen anymore.
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11643
                  ok on touch screen?
                  Try old file
                  • darckreign1984
                    • 260
                    • Romania
                    Try old file
                    i tried, tablet started, same error - i press ok with mouse, some seconds logo from hp was posted, then restart, and again same bootloop .
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11643
                      Find out if there are any more spi chips on the device, post it here if there is one.
                      • darckreign1984
                        • 260
                        • Romania
                        i posted already all 3 chip
                        W25Q80DV@WSON8 ori - on the back oon the wvan conector
                        W25Q64JV@WSON8 read ori.BIN - near cpu same side
                        and
                        1012-g2.bin - its writed on W25Q128JV@WSON8 - near ssd and sim conector
                        • darckreign1984
                          • 260
                          • Romania
                          the tablet was working with another bios fix, fixed in other thread that did not recognized any wifi - until i make factory default, and started the bootloop (and the attept to spin the fan like 5 degree)
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11643
                            W25q64jv@wson8
                            • darckreign1984
                              • 260
                              • Romania
                              W25q64jv@wson8
                              Post 3 have this backup from this motherboard
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11643
                                HP Elite x2 1012 G2 Tablet
                                • darckreign1984
                                  • 260
                                  • Romania
                                  I tried this fix, for some reason - stil not functional, fan will do at first 3-4 spin then will TRI to rotate 10 degree let say now. Buth the motherboard it's heating up and for Shure require that fan need to rotate.
                                  I tried this EC, and the bios that i post in first post, and at first start it show
                                  Picture attached.
                                  After the message, it take a little then display the error for data mismatch, ai press OK with the mouse, it reset and screen don't show again, and it's in bootloop.
                                  • darckreign1984
                                    • 260
                                    • Romania
                                    i see something strange, that i ignored before.
                                    if i test diferent variant of bin, the caps led blink code change.
                                    it can be
                                    3 blink
                                    3 blink + 1 short
                                    4 or 5
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 11643
                                      it can be
                                      3 blink
                                      3 blink + 1 short
                                      4 or 5
                                      The files I have posted are all based on the file you posted in #1, may need more time to repair itself after flashing.
                                      • darckreign1984
                                        • 260
                                        • Romania
                                        I don't understand what after a factory reset in bios tablet don't display nothing.
                                        How mutch time to let the tablet to make this bootloop
                                          HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                          This specification for the HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet (ENERGY STAR) boardview and Elite x2 1012 G2 Tablet (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 07:10 AM
                                          HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                                          This specification for the HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet boardview and Elite x2 1012 G2 Tablet schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-06-2024, 06:30 AM
                                          09-06-2024, 06:10 AM
                                          09-06-2024, 05:46 AM
