HP hp zbook firefly 14 g8
    • 20914
    Re: HP hp zbook firefly 14 g8 25Q256 (32mb)
    Originally posted by anhbanxoi
    Your feature byte missing some digits at the end.
    Originally posted by Vesko356
    They are not missing - it's just the row of symbols is so long that it doesn't fit in the place.
    Code:
    3X476J6S6b7B7M7Q7U7W7m7saBapaqauawb8bUbhcAdUdpdqfPguhKhWhkjhk8mEmwnVng.ra
    The forum has a 50 text character limit then it will make a space, there`s no limit afaik in a code box.
    Example: forum50characterlimitforum50characterlimitforum50characterlimitforum50characterlimit
    If a feature byte is copied from here and pasted it will have a space,the feature byte from post #12 has a space between the A and f
    3X476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAdUdpdqfA fPgSguhKjhk8mEmwnVng.By <--- remove the space
    • black0hackers
      • Jul 2020
      • 367
      all donations are welcome,
      HI. thanks for your help. this file worked. but very slow turn on hp logo and have some problem in drivers!
        • 20914
        Clean the ME firmware to fix the slow boot,and install audio drivers from HP support
        How to clean ME/TXE region https://www.badcaps.net/forum/showpo...41&postcount=3
        • iaf86
          • Mar 2017
          • 36
          Restore Factory settings in Main tab then restore Factory settings in Security tab and write all information below using tool in the attachment.
          Product Name : HP ZBook Firefly 14 inch G8 Mobile Workstation PC
          Serial Number: 5CG12264S7
          SKU : 1A2F2AV
          BuildID : 21WWCVCT601#SABG#DABG
          Feature Byte : 3X476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAdUdpdqfAfPgSguhKjhk8mEmwnVng.By
          System Board CT Number : PKPRU00WBF90PX
          thank you so much work 100%
          • iaf86
            • Mar 2017
            • 36
            HP hp zbook firefly 14 g7 Bios password
            Please help me to unlock the bios password . i am uploading original bios backup . thankyou
            Last edited by Vesko356; 08-24-2023, 02:40 PM. Reason: Bios removed, thread hijack.
            • volinakis
              • Jan 2021
              • 2733
              • N/A
              #26
              Re: HP hp zbook firefly 14 g7 Bios password
              wrong thread, yours is HP ZBook Firefly 14 G7 Mobile Workstation. You opened a new thread for it but you uploaded bios named "Hp zbook firefly 14 g8 bios" ...
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #27
                Read the rules before posting:
                You MUST NOT:
                • Hijack threads unrelated to your request
                • Post a request in multiple threads
                • Post a request multiple times
                • Post in foreign (non-English) languages
                • Share private contact information
                • Offer payment of any kind whatsoever
                • Bump your thread or post more than once every 48 hours. If you do so you will receive an infraction
                You MUST:
                • Read BIOS guides, methods, resources and tools
                • Try the method at BIOS guides, methods, resources and tools before requesting help
                • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                • Use search function in case someone already answered your request
                • Post under a related thread if it exists
                • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                • Name your thread with model numbers and request
                • Provide a BIOS/EC dump if possible
                • Attach files directly to your post instead of linking to external websites
                • Post what the problem is,be specific - Black screen,no boot,running slow,password.
                • Do NOT post "clean me","clear bios","clean bios","bios need" or other such terms
                Become a Badcaps supporter
                Thanks to all supporters.
                • kudo623
                  • Aug 2022
                  • 56
                  Tried RCunlocker tool said wrong chip try unlocking 16MB chip.
                  32MB file enclosed. Thanks!
                  • kudo623
                    • Aug 2022
                    • 56
                    Hi There was a typo --My system board is a Firefly G7 not G8 as was written on the back cover of the laptop.
                    I apologize for the error.
                    • volinakis
                      • Jan 2021
                      • 2733
                      • N/A
                      #30
                      your bios is for "HP ZBook Firefly 14 inch G8 Mobile Workstation Q PC" also S/N embedded in bios indicates the same.
                      At 1st boot press F10 and RESET BIOS to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the cover. Or extract DMI from your bios dump:
                      Feature Byte: 3X476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwnVng.Yq (no spaces)
                      Serial: 5CG1416RQ3
                      SKU: 533D0US#ABA
                      Build ID: 21WWCVCT601#SABA#DABA
                      Board CT: PKUHE00WBFS0RY
                      Name: HP ZBook Firefly G8 Mobile Workstation PC
                      Save and use BCU to exit MPM mode or restart laptop/desktop how many times counter shows.
                      REMOVE CMOS BATTERY BEFORE WRITING BIOS!
                      • kudo623
                        • Aug 2022
                        • 56
                        Serial: 5CG1416RQ3
                        SKU: 533D0US#ABA
                        Thanks a Million for walking me through that and providing the instructions to do it! It worked! Was wondering why the RCunlocker exe tool did not produce an unlock bin for me? Do I not have the correct version?
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #32
                          Because the tool does not support this particular model.
                          • kudo623
                            • Aug 2022
                            • 56
                            OK Thanks Vesko
                            Will that bin file you sent me (firefly 14 mod-g8.bin) work on other firefly 14 G8 to clear their password? Thanks.
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #34
                              OK Thanks Vesko
                              No. You must start over - read the bios from the other machine, and upload the dump here for unlock.
                              • kudo623
                                • Aug 2022
                                • 56
                                Please help me again with unlocking this HP firefly G8 bin for me,
                                Thank you!
                                Last edited by Vesko356; 08-26-2023, 10:43 PM. Reason: Bios removed, thread hijack.
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #36
                                  Thank you!
                                  Read post #27.
                                  Attached dump in your post has been removed. It's for HP ZBook Firefly 14 G7 Mobile Workstation with serial number 5CG1019M60
                                  • kudo623
                                    • Aug 2022
                                    • 56
                                    OK sorry about that. I'll try to be more careful next time.
                                    • kudo623
                                      • Aug 2022
                                      • 56
                                      Firefly 14 G8 need unlocked
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11738
                                        #39
                                        Unlocked
                                        • kudo623
                                          • Aug 2022
                                          • 56
                                          Hi the unlocked bin did not work
                                          Caps lock LED on solid a few blips on power LED light
                                          No POST
                                            HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation Specification for Upgrade or Repair
                                            This specification for the HP ZBook Firefly ZBook Firefly 14 G8 Mobile Workstation Bundle Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Firefly 14 G8 Mobile Workstation Bundle boardview and ZBook Firefly 14 G8 Mobile Workstation Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                            09-07-2024, 05:20 AM
                                            HP ZBook Firefly 14 G7 Mobile workstation Specification for Upgrade or Repair
                                            This specification for the HP ZBook Firefly 14 G7 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Firefly 14 G7 boardview and Firefly 14 G7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                            09-06-2024, 07:20 PM
                                            HP ZBook Firefly 15 G7 Mobile workstation Specification for Upgrade or Repair
                                            This specification for the HP ZBook Firefly 15 G7 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Firefly 15 G7 boardview and Firefly 15 G7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
