HP Zbook Studio G5 - Clear ME Please
  • KELO1981
    • Oct 2019
    • 14
    Hi!
    Need clear ME Region bios dump for HP Zbook Studio G5 (board DA0XW1MBAI1 intel i9-9th gen), please. The board looks like is trying to boot, all voltages present, fans at full blast at the end of the boot cycle. The board has 3 bios chips Main, EC and TR. I extracted only main bios 32mb.
    Thank you,
    Alex
  • hoaca388
    Badcaps
    • Jan 2022
    • 12278
    Re: HP Zbook Studio G5 - Clear ME Please
    Here
    • KELO1981
      • Oct 2019
      • 14
      Works but unfortunaly stuck on system bios update. Maybe the original bios was corrupted (i had to replace one mosfet and pwm chip due to short)
      • KELO1981
        • Oct 2019
        • 14
        This is first bios dump i did, could you please clear this one for me, thank you
        • lapfix
          • Mar 2020
          • 2756
          • my workshop
          This is your clean me file
          • KELO1981
            • Oct 2019
            • 14
            This bios is not working I am not able to boot up and get 2 long beeps with power light blinking followed by pause and then 2 short beeps
            • lapfix
              • Mar 2020
              • 2756
              • my workshop
              What's the original dump ! post n 1 or n4 !!
              • KELO1981
                • Oct 2019
                • 14
                Sorry no 4
                • EffiSon
                  • May 2020
                  • 38
                  • Sweden
                  Sorry if that is off topic
                  I bought the replacement motherboard for HP ZBook Studio G5 and was playing with its BIOS while accidentally i changed the display setting to ONLY discrete and since then i never got a display
                  Laptop keeps beeping and restarting and i have a doubt that its discrete NVIDIA card is not functioning either from the beginning or because of my some wrong bios configuration
                  So now the question is how can i reset the bios to its default setting ?
                  Thanks in advance
                  • EffiSon
                    • May 2020
                    • 38
                    • Sweden
                    Can someone please put that bios settings to default ? or does the clear me works the same ?
                    Edit:
                    Created a new topic instead of taking over other person thread
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12278
                      Rule : https://www.badcaps.net/forum/troubl...before-posting
                      • EffiSon
                        • May 2020
                        • 38
                        • Sweden
                        Originally posted by hoaca388
                        Sorry about that and thanks for sharing the rules to remind about it.
                        Created a new thread now
                          SMDFlea commented
                          Editing a comment
                          You don`t have to start a new thread, just post the laptop serial serial number !
                      • EffiSon
                        • May 2020
                        • 38
                        • Sweden
                        Edit:
                        Description : HP ZBook Studio G5
                        ProdID 2ZC51EA¤AK8
                        S/N ¤ 5CD92348V3​
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12278
                          ProdID 2ZC51EA¤AK8
                          S/N ¤ 5CD92348V3​
                          HP ZBook Studio G5 Mobile Workstation
                          • EffiSon
                            • May 2020
                            • 38
                            • Sweden
                            That does not work.
                            Can you please make this bios dump to default settings ?
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 12278
                              That does not work.
                              You have a hardware problem.
                              • EffiSon
                                • May 2020
                                • 38
                                • Sweden
                                But that dump is from another reserv board which has MXIC chip and even was functional as well. The only change i made was change display settings to discreate ONLY, and since then this Laptop turn on with fans spinning but beeping and no display.
                                Earlier i thought Winbond bios will work on MXIC board but I think they are not compatible with each other.
                                Therefore shared MXIC dump so please clean that plus make sure that the settings are set to default values.
                                Because I am sure by changing configuration to default will work on that board
                                NOTE: I have 2 HP Zbook G5 boards, one with Winbond and other with Mxic. Board with Winbond could have hw problem since not turning on anymore.
                                • EffiSon
                                  • May 2020
                                  • 38
                                  • Sweden
                                  That does not work.
                                  Can someone please clear this bios and / change its setting to default if possible
                                  ProdID 2ZC51EA¤AK8
                                  S/N ¤ 5CD92348V3​
                                    • 21692
                                    ProdID 2ZC51EA¤AK8
                                    S/N ¤ 5CD92348V3
                                    try these 2 bios. zbook_backup1 first
                                    • EffiSon
                                      • May 2020
                                      • 38
                                      • Sweden
                                      Did try both of them, bios zip won't even power on the device no fan spin where as zbook bakcup1 zip did not show any display though fan runs at full speed
                                      Got confused ;(
                                      Any more ideas or help
                                        HP ZBook ZBook Studio G5 Mobile Workstation Mobile workstation Studio Specification for Upgrade or Repair
                                        This specification for the HP ZBook ZBook Studio G5 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Studio G5 Mobile Workstation boardview and ZBook Studio G5 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-06-2024, 07:05 AM
                                        HP ZBook ZBook Studio G3 Mobile Workstation Mobile workstation Studio Specification for Upgrade or Repair
                                        This specification for the HP ZBook ZBook Studio G3 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Studio G3 Mobile Workstation boardview and ZBook Studio G3 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-06-2024, 06:02 AM
                                        HP ZBook ZBook Studio G3 Mobile Workstation Ultrabook Studio Specification for Upgrade or Repair
                                        This specification for the HP ZBook ZBook Studio G3 Mobile Workstation Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Studio G3 Mobile Workstation boardview and ZBook Studio G3 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                        09-06-2024, 05:30 AM
                                        HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation Studio Specification for Upgrade or Repair
                                        This specification for the HP ZBook Studio G4 + DreamColor Z27x Studio Display Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Studio G4 + DreamColor Z27x Studio Display boardview and Studio G4 + DreamColor Z27x Studio Display schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                        09-06-2024, 06:00 AM
                                        HP ZBook ZBook Studio G3 Mobile Workstation Ultrabook Specification for Upgrade or Repair
