HP 15-bs109np keeps corrupting bios
  • Vspeed
    • May 2022
    • 53
    • Portugal
    Have this laptop that wouldn't show any signs of life, sometimes had a bit of fan spin, others, just a very dim CAPS LED blink.
    Cleaned dumped ME bios region, the laptop power on fine again. After turning it off, it shows the same behavior.
    What is causing this?
    Uploaded original dumped bin, original ME cleaned bin and untouched bin files from HP website.
    Thank you.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Re: HP 15-bs109np keeps corrupting bios
    HP Notebook - 15-bs109np
    • hoaca388
      Badcaps
      • Jan 2022
      • 12441
      And some other versions.
      • Vspeed
        • May 2022
        • 53
        • Portugal
        Have an update. Just flashed the cleared ME bin again, and the laptop doesn't boot. Just the power LED lights up. No HDD activity.
        Can I just flash any of those bin files? shouldn't some serial numbers be copied over from the original bin over to those?
        • hoaca388
          Badcaps
          • Jan 2022
          • 12441
          At #2. 08328 , dmi added.
            • 22276
            Check the chipset support with ME Analyzer. There`s no need to post them. HP bundle multiple updates for different machines in the same update.
            084D4 is Gemini Lake
            0832D is Braswell/Cherry Trail
            0832E is Apollo Lake
            08445 is WPT-LP Wildcat Point
            The 15-bs109np has a i5-8250U CPU , Skylake/Kaby Lake . 08328
              • 22276
              Flash the bios at post #2 ,its a virgin bios with clean configured ME FW . If it doesn`t work then its a hardware problem.
              • Vspeed
                • May 2022
                • 53
                • Portugal
                Yeah, flashed #2, the laptop powers on, there is fan spin, then it powers itself off after around 10s, not powering on itself again.
                When pressing power afterwards, there is a shorter fan spin and the CAPS LED seems to flash randomly.
                Which hardware issue can it be? It powered fine once after cleaning ME, now it's not doing it again.
                • Vspeed
                  • May 2022
                  • 53
                  • Portugal
                  Problem solved.
                  Upon close inspection to the side of the board facing the keyboard, found a slight corrosion or water damage in Q21 located close to the usb ports.
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    11-14-2025, 04:04 PM
                  • Kentsfield
                    Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
                    by Kentsfield
                    I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
                    Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
                    I desoldered the flash IC MX25U12872F and dumped the flash.
                    I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
                    08-04-2025, 07:46 AM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • istvanszasz99
                    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                    by istvanszasz99
                    Product ID: RZ09-0421
                    Motherboard: CH580
                    Bios File Size: 32,768 KB
                    Dear Forum Readers!
                    !!! MY RAZER BLADE...
                    11-24-2025, 05:52 PM
