Lenovo Legion S7 15IMH5
  • Schizh
    • Dec 2022
    • 11
    • Finland
    Looking for help to find a good BIOS to flash on my bricked Legion Slim 7
    Model: S7-15IMH5
    System type: 82BC
    Serial nr: PF24XRYM
  • peste
    • Dec 2016
    • 13721
    • ROMANIA
    Re: Lenovo Legion S7 15IMH5
    Model: S7-15IMH5
    System type: 82BC
    Serial nr: PF24XRYM
    always when you make a bios request post the original bios even if it is corrupted..
    • Schizh
      • Dec 2022
      • 11
      • Finland
      Don't have a backup or tools right now to make a backup of the original bios.
      Can the one available on Lenovo's page be used (still new to this, so unclear what can and can't do)?
      https://download.lenovo.com/consumer...s/fdcn41ww.exe
      • peste
        • Dec 2016
        • 13721
        • ROMANIA
        you need the original bios from the laptop for the DMI information, not the update from the website....you do this with an SPI programmer...I sent you an informative video...
        https://www.youtube.com/watch?v=DWWigscuQDY
        • Schizh
          • Dec 2022
          • 11
          • Finland
          Only just recently got my hands on a programmer.
          Don't know if i'm doing things right, but here's a readout of the bios.
          • peste
            • Dec 2016
            • 13721
            • ROMANIA
            you are not doing well...the content is empty...have you seen the video from post#4??
              • 22084
              are you using a ch341a and a clip
              • Schizh
                • Dec 2022
                • 11
                • Finland
                Sorry, zipped/uploaded the wrong file.
                My first try was empty, as you noticed - learning by doing.
                Here's the right file.
                Thanks for replying so quickly.
                • peste
                  • Dec 2016
                  • 13721
                  • ROMANIA
                  try..
                  DMI 4D0000 - 4D022F
                  • Schizh
                    • Dec 2022
                    • 11
                    • Finland
                    try..
                    DMI 4D0000 - 4D022F
                    Thank you.
                    Can you please support a bit more and explain what you mean by "DMI 4D0000 - 4D022F"?
                    • peste
                      • Dec 2016
                      • 13721
                      • ROMANIA
                      Thank you.
                      in this range is the DMI information (serial number, model, etc...)
                      • Schizh
                        • Dec 2022
                        • 11
                        • Finland
                        Ok.
                        But I should be able to just try to program this bin-file to the bios chip now?
                        • Schizh
                          • Dec 2022
                          • 11
                          • Finland
                          Went ahead and tried to program the file.
                          It successfully programmed, according to the program. However computer won't start and if verify IC it gives the following error:
                          "Verification error on address: 0x00000109, Device: 0x55, Buffer: 0x57"
                          • Schizh
                            • Dec 2022
                            • 11
                            • Finland
                            Did another try to program. Erased IC before flashing and the programmed with the DMI information inserted.
                            New error while Verifying IC:
                            "Verification error on address: 0x00061F00, Device: 0xFF, Buffer: 0xFB"
                            • peste
                              • Dec 2016
                              • 13721
                              • ROMANIA
                              at post #4 you have a video how to do it if you use the clip you will have errors because the clip does not make firm contact with the chip...
                              • Schizh
                                • Dec 2022
                                • 11
                                • Finland
                                Tried and tried, now I got a successful programming/write and also IC verify. But unfortunately still the PC won't start.
                                Just as background information. Previously (before new bios) the PC would light-up and spin-up but not boot to bios or anywhere. Now it is totally silent and black.
                                • Schizh
                                  • Dec 2022
                                  • 11
                                  • Finland
                                  Any tips on other things to try is most appreciated.
                                  As said, managed to program the bios successfully with the provided file - but the PC is totally dead.
                                  • ecolaptop
                                    • Jan 2022
                                    • 10
                                    Hi.
                                    Thank you for being here guys.
                                    I have an issue with my s7 as well.
                                    I went ahead and dumped the original bios from my W25Q128JV Lenovo Legion s7 15IMH5
                                    S/N: PF2KVBVQ
                                    I believe bios is corrupted and i would like a new instal but as there is only one available and i have it already i cant just install it from windows level as you know.
                                    I will attach original dump.
                                    Would someone kind enough help me with getting new bios and importing all my serial numbers and other info from my original dump to nice and clean and fresh bios file so i can program it to my s7?
                                    Thank you for your time and effort in doing so i appreciate it.
                                    Stay safe.
                                    • danito
                                      • Jun 2016
                                      • 1141
                                      • Romania
                                      Originally posted by ecolaptop
                                      Hi.
                                      S/N: PF2KVBVQ
                                      Stay safe.
                                      No DMI
                                      backup with Uone
                                      lenovo_autopatcher_0.2.zip (https://www.badcaps.net/filedata/fetch?id=2224617) Hello everyone! In the past several weeks I've learned a lot from this forum and its community especially from all the folks who contributed to THIS (https://www.badcaps.net/forum/showthread.php?p=980956) thread With some trial and error I was able
                                      • ecolaptop
                                        • Jan 2022
                                        • 10
                                        Thank you for repaired dump ill try soon.
                                        I'm new to bios at the level you talk - i might have presented myself as more knowledgeable thank I'm - I'm just a fool.
                                        I understand you did not find an abstraction layer provided by my system management BIOS that provides information about my computer's hardware to my operating system and you want me to back it up using Universal BIOS Backup Toolkit 2.0
                                        I just tried and get error of can not identify bios - lol something is really wrong with it.
                                        I used x gecu programmer and clips instead of removing the chip - might that be a reason? - I did not get any errors while doing so that is why i assumed this was success read.
                                        I can unsolder it and read again if that helps.
                                        What would you suggest?
                                        Sorry to be a pain.
                                        Stay safe.
                                          Lenovo Legion Slim 7 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Slim 7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Slim 7 boardview and Slim 7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Legion...
                                          09-07-2024, 07:12 AM
                                          Lenovo Legion Slim 5 Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo Legion Slim 5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Slim 5 boardview and Slim 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo Legion...
                                          09-07-2024, 06:38 AM
                                          09-07-2024, 05:20 AM
