Hi, I have an HP with AMD chipset that fail at power on with this caps lock led code error: five caps lock slow white led flash + 3 fast white led flash.
I reprogrammed the BIOS IC with a file found on the net named "HP AMD FIXED.BIN" and the notebook turned on again but after a few minutes, about 15-20, the screen went black again and I had to force shut it down.
The same led code error appears the next time it is switched on.
After several minutes of being turned off, the notebook turns on again normally.
Could it be a bios IC problem or a chipset damaged solder points due to poor heat dissipation for improper use?
