Acer a315-55g-73n7
  • luigi55
    • Jun 2022
    • 20
    • Italia
    Acer a315-55g-73n7
    Not even a total dead LED lights up, the customer says he sparked the power supply in the power jack which I found broken, in fact I power it with soldered cables on main, replaced the power jack input diode which was broken. Mod. mb DA0ZAWMB8E0 rev.E
    Thank you
  • mon2
    • Dec 2019
    • 14118
    Re: Acer a315-55g-73n7
    Need voltage checks. See attached. Post the measurement of each test point.
    Meter in DC volts (20V or higher scale) -> attach your power adapter.
    Measure the voltage to ground of each test point.
    • luigi55
      • Jun 2022
      • 20
      • Italia
      On pq1 and only on pin 1 19v on the remaining pins of pq1 0v and 0v also on all the other indicated points (2/3/4 etc) Thanks
      • mon2
        • Dec 2019
        • 14118
        Can you measure the voltages on pin #28 of the charger IC? This is the power pin on the charger IC.
        Confirm again that REGN pin #24 on the charger IC is 0 volts?
        After the above checks, remove all power. Meter in resistance mode.
        Check the resistance to ground of the REGN pin on the charger IC.
        • luigi55
          • Jun 2022
          • 20
          • Italia
          I found on 28 19v, on other pins: 5 variable value from 0 to 3v on 6 2.55v on 24 6v
          • mon2
            • Dec 2019
            • 14118
            Power down. Remove the 4k resistor on the ACDRV pin. Do not lose this part.
            Power up again. Then carefully measure the voltage to ground on the ACDRV pin.
            What is the voltage? It should be ~25v.
            • etarcadia
              • Sep 2023
              • 8
              • Italy
              Hi there,
              I have the same acer "A315-55G-73N7" ,after inserting USB stick it turned off and never turned back on again.
              I tryed resetting the bios but to no avail.
              Can you help me?
              • mon2
                • Dec 2019
                • 14118
                How did you reset the bios? Reflashed it or the laptop boots to the BIOS screen?
                • etarcadia
                  • Sep 2023
                  • 8
                  • Italy
                  the laptop doesn't start .
                  When I push power button doesn't work
                  • mon2
                    • Dec 2019
                    • 14118
                    Review the attached. With extreme care, with the power adapter connected -> measure the voltage to ground of each highlighted pin.
                    Post each measurement.
                    • etarcadia
                      • Sep 2023
                      • 8
                      • Italy
                      (PU1) Measurement:
                      pin 3 CMSRC =19,1v
                      pin 4 ACDRV =24,9v
                      pin 28 VCC =18,9v
                      pin 6 ACDET =2,6v
                      pin 1 ACN =19,1v
                      pin 2 ACP =19,1v
                      pin 24 REGN =6v
                      • mon2
                        • Dec 2019
                        • 14118
                        These are all good voltage measurements in the shared list.
                        • etarcadia
                          • Sep 2023
                          • 8
                          • Italy
                          Can I do other?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Since mosfet biasing is correct at voltage input and 19V is flowing thru the mb, next step is to check whether you have 3V & 5V on coil and status of 3V LDO.If all is well till here, then check powerbutton has 3V or not and if its present, does de-bounce logic works i.e, 3v goes to zero when power button is pressed and comes back to 3V.
                            You should make backup of your main bios and flash with a clean me version.
                            • etarcadia
                              • Sep 2023
                              • 8
                              • Italy
                              I connected the power to motherboard and to pin n° 1 of fan connector and there isn't 5 volts.
                              The trace is attached.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Why you are after the fan at this stage when motherboard is not even turning on? Report back on post#14
                                • etarcadia
                                  • Sep 2023
                                  • 8
                                  • Italy
                                  Sorry I took wrong way.
                                  I 'll check LDO
                                  • etarcadia
                                    • Sep 2023
                                    • 8
                                    • Italy
                                    Can you help me how to proceed to verify LDO since the electrical diagrams do not fully correspond to my motherboard
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Locate the PWM for 3V and tell us the top markings on it. We can tell you the pin number where you need to measure.
                                        09-06-2024, 05:27 AM
                                        Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                        This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                        09-07-2024, 05:00 AM
                                        Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                        This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 04:10 AM
                                        Acer Swift SF314-511-38U6 + Pack Gold Acer 14'' Notebook 3 Specification for Upgrade or Repair
                                        This specification for the Acer Swift SF314-511-38U6 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-38U6 + Pack Gold Acer 14'' boardview and SF314-511-38U6 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-07-2024, 03:10 AM
