Hp -15bs199nl not charching
  • arber1232
    • Dec 2019
    • 377
    • Albania
    hello how are you .... i have a laptop hp 15bs199nl which does not charge. When I put the power supply, the dc light turns orange but the laptop does not charge. I thought it was the battery, but luckily I have another laptop like that and I realized that the defect is the board. I changed the 8q25a ic charging but no change anything ..
    I see that this laptop has the same charging scheme as the hp 250 g6, the scheme I found in this forum, I made some measurements but I don't understand where the defect is.
    I am also uploading the scheme, if you help me tell me where to make the measurements. 19 Vin is ok laptop turn on with battery
    With charger and battery input voltage in PL13 PL14 is 14.4 v
    voltage in ic charger + battery
    20=vcc-19.43v
    19=Phase 14.41 v
    18=hidrv ov
    17=Btst 14.13 v
    16=Regn 6v
    11 Badrv 14,39
  • mon2
    • Dec 2019
    • 14316
    Re: Hp -15bs199nl not charching
    See attached.
    Attach the power adapter. Meter in DC volts (20V or higher) scale.
    Red meter probe to pin to test.
    Black meter probe to ground.
    Measure the voltage to ground of each requested test point (#1..5).
    Often the 2nd DCin mosfet gets damaged and has to be replaced but perform these checks to confirm the details.
    • arber1232
      • Dec 2019
      • 377
      • Albania
      Originally posted by mon2
      See attached.
      I explain in photo voltages
      • mon2
        • Dec 2019
        • 14316
        Replace PQB12 mosfet.
        • arber1232
          • Dec 2019
          • 377
          • Albania
          what voltage will I have after the change?
          • mon2
            • Dec 2019
            • 14316
            The fault is that the GATE voltage is not = DCin + REGN = ~25 volts.
            Respectively, the gate voltage is 19v. For N-channel mosfets, the GATE voltage has to be HIGHER than the voltage passing between source & drain pins.
            You have 19v on both sides of this mosfet (source & drain) so the mosfet is leaking if the gate is also 19v.
            Remove all power / no battery.
            Remove the series 4k resistor on the ACDRV pin and power up. Do not lose this 4k resistor.
            Power up again with the adapter.
            Do you see now ~25 volts on ACDRV pin? That is expected as the normal gate drive voltage. It has to be a boosted voltage for the N-channel mosfets to enable.
            With 19v on the gate, you should have 0 volts on the drain side of this mosfet since the mosfet should be OFF.
            • arber1232
              • Dec 2019
              • 377
              • Albania
              i change but is same voltage 19.33v
              • arber1232
                • Dec 2019
                • 377
                • Albania
                I remove 4k resistor now i see on pl14 and pl13 voltage is 15,34v myabe now laptop charching
                • mon2
                  • Dec 2019
                  • 14316
                  If you have removed the 4k resistor and you still have voltage on the drain of the 2nd mosfet then the DCin mosfets are leaking. They should be OFF if the gate voltage is not ~25 volts.
                  Start with replacing the 2nd mosfet and check if the drain pins are now 0 volts. It should be 0 volts since the gate voltage is missing.
                  It is possible that the first mosfet is also defective but start with replacing the 2nd mosfet.
                  Q: What is the voltage to ground of ACDRV without the 4k resistor ?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Check if PQB1 is defective. Most often it fails in this platform.
                    • arber1232
                      • Dec 2019
                      • 377
                      • Albania
                      when i change pqb12 and remove 4k resistor laptop charching ok now . Acdrv without 4k resistot is 19.73 v . but laptop charching ok now
                      In drain 2nd mosfet i have 19.08 v
                      • arber1232
                        • Dec 2019
                        • 377
                        • Albania
                        i change before but is same not charching
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Surprising for me.
                          • mon2
                            • Dec 2019
                            • 14316
                            PQB12 is still a suspect. The voltage must be going through the internal body diode.
                            What is the voltage to ground of ACOK (pin #5) of PUB1 ?
                            Remove all power -> meter in resistance mode.
                            Measure the resistance across the 2nd mosfet pins (PQB12):
                            source (1-2-3) & drain (5-6-7-8)
                            source (1-2-3) & gate (4)
                            gate (4) & drain (5-6-7-8)
                            Also, ACDRV should be ~25 volts if the 4k resistor is removed. Have you replaced PUB1 (BQ Charger IC) yet ? It may be defective if REGN = ~6 volts.
                            With the 4k resistor (PRB9) connected & ACDRV ~19v -> PQB12 should be OFF.
                            • arber1232
                              • Dec 2019
                              • 377
                              • Albania
                              What is the voltage to ground of ACOK (pin #5) of PUB1 ? 3.3 v
                              source (1-2-3) & drain (5-6-7-8)---- 330 k ohm
                              source (1-2-3) & gate (4) 2.1 ohm
                              335k ohm
                              i replplaced pub1
                              a clarification so that we are not misunderstood, I am working with the HP 15bs199nl model, maybe the scheme changes a little. But now the laptop seems fine and is charging ok without 4k resistor
                              • mon2
                                • Dec 2019
                                • 14316
                                SCL ; pin # 9
                                SDA ; pin # 8
                                • arber1232
                                  • Dec 2019
                                  • 377
                                  • Albania
                                  what is the voltage to ground of
                                  acok (pin #5) of pub1 ?
                                  scl ; pin # 9
                                  sda ; pin # 8
                                  acok 3.3 v
                                  scl 3.3v
                                  sda 3.3v
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    I'm puzzled as well as baffled by this case. How can ACDRV be 19V without 4K resistors in place?? So, to me either charging IC and/or PQB12 is defective.
                                    @arber1232, dont deliver the laptop to customer in such a state, as there may be consequences unknown. May cost you your reputation.
                                    @mon2, I want to know if PQB12 is passing voltage in diode mode(which i also beleive), how battery can charge?? Do you have any clue?? Honestly, i dont have one.
                                    PS: I'll still bet for PQB12 shorted between S-G pins.
                                    • arber1232
                                      • Dec 2019
                                      • 377
                                      • Albania
                                      @mcplslg123 no not sent laptop in costumer becouse i test now and laptop charching and cut off ..
                                      I am surprised that pbq12 pin 123 with pin 4 has 2.2 ohm... maybe they are in same line ?
                                      i change pqb12 with 7406 mosfet
                                      • arber1232
                                        • Dec 2019
                                        • 377
                                        • Albania
                                        PS: I'll still bet for PQB12 shorted between S-G pins.[/QUOTE]
                                        yes
                                        when i remove 4k resistor laptop chrching with it battery not charching
                                        • Damex 29
                                          Dynabook l50-g 11j scheme
                                          by Damex 29
                                          looking for scheme robusta 6050a3128301 a01
                                          Dynabook l50-g 11j
                                          04-02-2025, 03:51 PM
                                        • dclass-pro
                                          HP Notebook With Strange Defect Does Not Turn On
                                          by dclass-pro
                                          Hi Guys, I have a HP DAX12AMB6D0 REV.D with a strange defect, that is on the 2nd mosfet on the power supply, the gate voltage does not reach 25V but pulses... if I try to touch some capacitors with my fingers, the voltage on the gate reaches 25V and the notebook turns on.
                                          I have already tried to change the charging connector, PU1 and PQ20 but I have not obtained any result, the problem still persists.
                                          Here are the voltages that I find ON PU1:
                                          Pin 1 - Pulses between 2 and 3v
                                          Pin 2 - Pulses between 2 and 3v
                                          Pin 3 - Pulses between 2 and 3v
                                          Pin 4 - Pulses between...
                                          01-31-2025, 08:27 AM
                                        • Art Em
                                          Need electric scheme for HP ENVY 13 with Moorea 13CS ICL 19728-1
                                          by Art Em
                                          Would be grateful if you send me the electro scheme for this motherboard, mentioned in title. If anyone is interested why:
                                          -first keyboard backlight stopped working
                                          - a couple months later the keyboard itself stopped working.
                                          - then, in two days, the laptop itself stopped booting.
                                          Thanks everyone in advance
                                          04-13-2024, 01:13 AM
                                        • arber1232
                                          Dell E7450 not charching La-A961P
                                          by arber1232
                                          HI, how are you. I have a dell laptop which does not turn on with charger and not charching
                                          the light of the power button for a while and turns off, with battery the laptop turns on and works fine. I have done some measurements and I doubt Pq705 but I want your help to be sure....
                                          Some measurements of pq 705 with charger without battery
                                          D1-19,13y
                                          S1/D2- voltage change 12v to 10v 13v
                                          G1- voltage change 13v, 14v, 16v
                                          G2-ov
                                          S2-gnd
                                          03-27-2023, 05:07 AM
                                        • maces
                                          SAMSUNG PS60E6500 Power Supply BN44-00513A defect and burned
                                          by maces
                                          I have a problem with the power supply of my Samsung PS60E6500.
                                          The LED of the TV is blinking and it doesn't turn on.
                                          After checking the power supply I noticed that the PCB board is burned at QP804 (K13A60D), the MOSFET is shorted.
                                          RP812 is also defect. Unfortunately the resistor is burned so I cannot read the value. Also QP805 and QP806 are shorted. Does anybody have a schematic diagram or does anybody know the type of the parts?...
                                          03-13-2023, 03:50 PM
