Macbook air logic boards 820-3437 and 820-00165 Backlight
  • mcnamj70
    • Oct 2022
    • 14
    Can anyone tell me if the Macbook Air logic boards 820-3437 and 820-00165 use the same backlight chip LP8550?
    Last edited by SMDFlea; 12-13-2022, 02:03 AM. Reason: logic boards 820-3437 and 820-00165
  • mon2
    • 14677
    Re: Macbook air logic boards 820-3437 and 820-00165 Backlight
    Yes, the same. You can purchase these from Texas Instruments, Arrow electronics or AliExpress.
    US $11.56 15%OFF | 5pcs/LOT 100%NEW LP8550TLX LP8550TLE LP8550 mark 8550 LED back light Driver ic U7701 for Macbook Air A1466 A1278 820-3437
    https://a.aliexpress.com/_mPOeosE
    • piernov
      • Jan 2016
      • 4439
      • France
      Stop buying garbage on Aliexpress. Mouser carries them.
      • korben_dallas
        Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
        by korben_dallas
        Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
        I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
        I'm new to soldering but the only feasible way to fix this issue is to do something myself.
        MY QUESTION:
        I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
        02-14-2024, 12:23 AM
      • ledbylight
        M1 A2337 Macbook - No Display, likely due to logic board
        by ledbylight
        Hi all!
        This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
        I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
        11-04-2024, 06:36 PM
      • defdjamel
        Solder won’t melt on MacBook 2021 logic board – need advice
        by defdjamel
        I’m trying to remove a component from a 2021 MacBook logic board, but I’m having trouble.
        https://www.electronicsdatasheets.co...s/tlv70733pdqn
        I’m using hot air at 480 °C with full airflow and good flux, but the solder paste is not melting.
        I know there’s a lot of thermal dissipation from the board, and I suspect the copper planes are absorbing most of the heat.
        Do you have any tips for this kind of board? Would a preheater help?
        Thanks in advance!
        09-05-2025, 08:56 PM
      • yuuki47
        A2681 M2 MacBook Air Dead Logic Board
        by yuuki47
        Hello...
        My sister purchased an M2 MacBook Air a year and a half ago. While she was using it a week ago, it randomly shut off and no longer powers on. There are no signs of life and not even the MagSafe indicator LED lights up.
        We took it to Apple and they disconnected the battery and tried a bunch of stuff before they declared the logic board "brain dead" and quoted us about £567 to replace it. Typical of them...
        eBay replacements run about £367 with the Touch ID sensor included.
        I did consider to probe the logic board for shorts...
        04-13-2024, 06:22 AM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
