Asus P5440F dead
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    Asus P5440F dead
    It worked regularly, I updated the bios and it went ok, even the restart. after i replaced the nvme unit and disconnected and reconnected battery .. total dead . I already tried to flash bios and ec rom ... nothing
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus P5440F dead
    You replaced the nvme while battery was connected?? Start with measuring resistance on all coils.
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      some caps in short
      • mon2
        • Dec 2019
        • 14020
        Use the lowest resistance scale on your meter and measure again. It appears you are measuring in the Kohms scale so low readings will be 0 ohms.
        • lordgeny
          • Apr 2016
          • 223
          • Italia
          thats it
          • Sephir0th
            • Oct 2020
            • 1262
            You were asked for resistance measurement and have shared voltages instead.
            FairRepair on YouTube
            • Bartoloni
              • Jul 2018
              • 140
              • Italy
              Hi guys i have this PC that after a bad battery replacement (broken traces on battery connector) have the IC called C34AH taking 70mA and with 2 legs shorted to ground (assuming pin 2 is GND looking at other ASUS board with diofferente layouts but same chip)
              the laptop is not powering on... i think that 11.5V come to this IC (data signals) burning it, anyone have an idea about the name?
              very thank you!
              (right now i can't remove IC because customer don't want the motherboard "touched".. not yet for warranty purposes)
              • JaroTech
                • Mar 2015
                • 351
                Hi, @Bartoloni the C34AH is from Amazing Microelectronic Corp. it is a low capacitance ESD protection array. I couldn't find the same chip, but an equivalent might be an AZC099-04S. I hope this will help you.
                • Bartoloni
                  • Jul 2018
                  • 140
                  • Italy
                  thank you Jarotech ...i have a C34SH from a similar ASUS board (same place near the battery connector) probably the same
                  • JaroTech
                    • Mar 2015
                    • 351
                    C34 is the device code, S is the date code and H is the control code, so it is the same chip.
                    If you look at the datasheet for the AZC099-04S, you will know the input and output of that chip.
                    • Bartoloni
                      • Jul 2018
                      • 140
                      • Italy
                      very thank you JaroTech!
