Macbook 12" - A1534 EMC 3099 - not charging battery
  • PenicheFix
    • Nov 2022
    • 6
    • Portugal
    Hello to everybody, I'm new on the repair and in the world of electronics, so I have a MacBook 12" A1534 from 2017, that it's slow and not charging the battery, and in the system it says "battery assistance required" it starts only with the dc adapter.
    I have already the pdf file and boardview that other colleague from this community put online, but I don't now where to start. It's possible some guide lines? many thanks in advance.
    Voltage: 20.03v
    Amperage: 0.166 to 0.266A
  • mon2
    • 14417
    Re: Macbook 12" - A1534 EMC 3099 - not charging battery
    Are you using the official and recommend power adapter for this laptop?
    If the adapter is under rated, the logic board will run slower and will be unable to charge the battery.
    • PenicheFix
      • Nov 2022
      • 6
      • Portugal
      Sorry the delay, yes I'm using the original one. I also have in J6950 - PPVBAT_G3H_CONN 8.71v
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • drlarsen
        MacBook Air M1 A2337 battery/charging issue
        by drlarsen
        Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
        I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
        On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
        After some hours, the battery status did not improve. Restore via DFU did not help.
        I connected the power adapter to a Kill-a-Watt...
        07-17-2025, 02:35 PM
      • Julian Bailey
        HP ProBook 445 G8 Battery not charging
        by Julian Bailey
        Hi all
        We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
        The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
        I have gone around the board with a MM and cant find anything
        Windows shows the battery fine,...
        10-11-2024, 10:34 AM
      • Schluchti45
        MacBook Pro A2141 replaced battery not booting from battery not charging. Works with power suppy
        by Schluchti45
        i ask if someone has a hint for me. I have a A2141. The original battery died and i replaced it with a new one form Ifixit. After the replacement the MacBook Boots only with the power supply.
        Coconut Battery is recognize the battery but it is not charging. When i remove the power supply the MacBook is immediately dead.
        11-18-2024, 02:05 AM
      • piernov
        Laptop battery charging circuit
        by piernov
        1. Some theory
        1.1. Introduction
        Almost every laptop has a charging circuit of some sort, that does a few things:
        • Manages switching between AC adapter and battery power
        • Manages battery charging and generates power rail to charge battery
        There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
        • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
        • Narrow VDC (NVDC)
        Texas instrument has a nice overview of these technologies with some more details at https:...
        11-15-2020, 01:31 PM
