Dell Inspiron 7567 LA-D993P odd charger issue
  • Johndill
    • Aug 2015
    • 314
    Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
    There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
    I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
    Here are the tested scenarios:
    1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
    2. With the laptop off, plug in charger (LED says on) & the front charging LED says it's charging. Turn laptop on & open bios battery settings, charger is detected & says charging (but it's not charging).
    Unplug charger, switches to battery, plug charger in, charger LED goes out (protection mode).
    3. Same test but with a 240W charger, laptop turned on, plug in 240W charger, laptop says charging but percentage does not move over time, the 240W does not trip out.
    4. Any charger can run the laptop without the battery connected.
    It seems as though the charging circuit has a partial short drawing too much Amps or something & tripping the lower wattage chargers?
    Any ideas what could be happening?
    I've just read @piernov "Laptop battery charging circuit" thread which is amazing but I'm not quite sure where my case fits. Thanks :-)
  • mon2
    • Dec 2019
    • 13830
    Re: Dell Inspiron 7567 LA-D993P odd charger issue
    Remove all power. Meter in resistance mode.
    Check the resistance across the mosfet pins.
    Review mosfets pq301, pq302 and pq306.
    Source & drain
    Source & gate
    Gate & drain
    Post each measurement of each mosfet.
    • Johndill
      • Aug 2015
      • 314
      PQ301:
      Source & drain - 0.4 ohm
      Source & gate - 0.425K ohm
      Gate & drain - 0.425K ohm
      PQ302:
      Source & drain - 11.5M ohm - 120K ohm with probes reversed.
      Source & gate - 8.6M ohm - 120K ohm with probes reversed.
      Gate & drain - 0.430K ohm
      PQ306:
      Source & gate - 0.434K ohm
      Gate & drain - 0.435K ohm
      • mon2
        • Dec 2019
        • 13830
        At least one of these mosfets is leaking. The resistance values are low.
        With care, remove mosfet pq306 and take the measurements again of the removed mosfet.
        Also measure the mosfets again that are on the board for the dcin side. Are the readings higher now that pq306 is removed?
        • Johndill
          • Aug 2015
          • 314
          PQ301:
          Source & gate - 7.1K ohm
          Gate & drain - 7.1K ohm
          PQ302:
          Source & drain - 220K ohm
          Source & gate - 220K ohm
          PQ306 (off the board):
          Source & drain - O.L
          Source & gate - O.L
          Gate & drain - O.L
          • mon2
            • Dec 2019
            • 13830
            Still with low resistance readings.
            Remove mosfet at pq301 and measure the resistance again.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Resistance on PR302??
              • Johndill
                • Aug 2015
                • 314
                Q301 (off the board)
                Source & drain - 0.2 ohm
                Source & gate - 7.6K ohm
                Gate & drain - 7.6K ohm
                PQ302 - all in the M ohm range
                PR302 - 0.1 ohm
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  You have a clear cut short to ground on CLR(PR302).
                  Remove the CLR and verify both the pads for resistance again. The side which is shorted, inject 1V there. You may increase the amps but voltage should'nt exceed 1V. Observe the amps consumed and look for hot component after injecting 1V for few minutes.
                  You need a dc supply/shortkiller to do this.
                  • Johndill
                    • Aug 2015
                    • 314
                    Sorry, that's a mistake, PR302 to ground is 30M ohms. :-)
                    I mistakenly measured across as I was with the mosfets.
                    • Johndill
                      • Aug 2015
                      • 314
                      Originally posted by Johndill
                      PQ301 (off the board)
                      Does this mean PQ301 is the fault? :-D
                      • mon2
                        • Dec 2019
                        • 13830
                        Pq302 readings are now ok.
                        These are the measurements of pq301 while it is off the logic board and on your work table? Or these are the measurements of the pcb pads where this mosfet was removed?
                        The readings are very low and indicate a short.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Ok, so no question of voltage injection. PQ301 readings looks bad. Confirm what @mon2 has asked.
                          • Johndill
                            • Aug 2015
                            • 314
                            Yes, measurement of PQ301 component itself on my workbench. :-)
                            • Johndill
                              • Aug 2015
                              • 314
                              I have an LA-C912P doner board (schematic attached). Is PQ707 on the doner board a good replacement for PQ301? :-)
                              • mon2
                                • Dec 2019
                                • 13830
                                Thanks.
                                Pq301 is for sure defective. Replace it and check the resistance again for these mosfets.
                                Datasheet for the donor mosfet pq307 is attached.
                                Yes, the donor mosfet is suitable and actually a better part than the original.
                                • Johndill
                                  • Aug 2015
                                  • 314
                                  Thanks.
                                  Thanks, PQ301 is replaced with the donor & PQ306 re-installed. All mosfet mesurements are in the Mega ohms. Good to test? :-)
                                  • mon2
                                    • Dec 2019
                                    • 13830
                                    Confirm the clr resistance to ground is not super low. This is the main power rail that powers the logic board.
                                    After this test, yes, power up to test again.
                                    • Johndill
                                      • Aug 2015
                                      • 314
                                      PR302 is around 15M ohms. :-)
                                      • Johndill
                                        • Aug 2015
                                        • 314
                                        Yes! It is charging & the percentage is going up! :-D
                                        We did it! Thank you so much for your assistance. Another laptop saved. :-D
                                        It currently at 42% now.
                                          DELL Inspiron 7567 Notebook 7000 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 7567 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7567 boardview and 7567 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 7567...
                                          09-06-2024, 08:01 AM
