New Lenovo P71 motherboard won't recognize Battery
  • nubie
    • May 2010
    • 64
    I got a P71 Motherboard (i7 7700HQ) for my Lenovo P70 so I could run a P3000 video card I had that my Clevo P770DM didn't like (It seems the Clevo likes the P4000 fine).
    Machine runs great, but will not recognize the battery. It either says battery 100% no charging, remaining time unknown, or it says 255% Battery not detected, or no battery.
    I used the maintenance USB Key to set machine type and Serial and it stopped complaining about that on boot.
    I did a BIOS load defaults, and it is up to date so I couldn't reflash the EC or the BIOS from Windows. I downloaded the Power Manager driver and made windows use it for the battery, which it did not do when installed.
    I have 170w and 230w power supplies, and the battery works fine in a second P70 I have here.
    Is it possible I just have a bad connection or a fault to the Battery communication terminals?
  • mon2
    • Dec 2019
    • 14667
    Re: New Lenovo P71 motherboard won't recognize Battery
    No, probably the TVS esd diodes on the smbus lines are defective. These parts protect against static charge surges on the battery connector. When they do their job, the part will short to ground.
    With care, measure the voltage to ground of each pin on the battery connector. Post each measurement.
    Also share a clean but close pic of the battery connector area. Then we can locate the esd diodes...likely a 3 pin device. Even better if you can post or link a schematic.
    • nubie
      • May 2010
      • 64
      The pins 3, 4,5 for SMBus and battery temp are all around 3.5v, in line with this schematic. The laptop is all together at the moment, will have to check the board later.
      • mon2
        • Dec 2019
        • 14667
        SMBUS voltage readings are good - the SCL / SDA lines are not stuck.
        For comparison - check the same readings on the working laptop.
        The logic boards are identical between the 2 units? You can charge or deplete the battery on the working logic board and the battery gauge properly reports the status? This confirms the battery is ok.
        Next would be to inspect the contacts of the battery connector on the logic board. Perhaps an issue with the EC chip that is the SMBUS master = often a 8051 embedded micro controller that communicates with the battery. Maybe needs to be reflashed? Wait on other comments.
        • dhenion
          Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
          by dhenion
          I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
          The original board was:
          ASUS X510UNR REV 3.0 A
          The replacement board is:
          ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
          It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
          01-30-2024, 01:45 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • code share
          Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
          by code share
          I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
          Here's what I've tried so far:
          • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
          • Booted successfully on AC power only with the battery disconnected
          • Visual inspection of the battery — no swelling, burn marks, or connector damage
          • Battery
          04-21-2025, 12:50 PM
        • mrkmpn
          Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
          by mrkmpn
          Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
          This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
          03-13-2024, 01:54 PM
        • dhs6512
          Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
          by dhs6512
          Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
          Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
          Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
          When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
          Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
          When connecting...
          10-29-2024, 11:04 AM
