Toshiba Satellite L50-A-122 Charger Light Pusling
  • Kambi13
    • Aug 2022
    • 134
    • Portugal
    Hi there, today in the menu, is a Toshiba Satellite L50-A-122 that has a puslng charger light.
    I've measured all the coils and the values seems ok, charger IC also seems, ok.
  • mon2
    • Dec 2019
    • 14255
    Re: Toshiba Satellite L50-A-122 Charger Light Pusling
    Charging LED = Orange color ?
    Is the pulsing not normal ? Could it just mean that the battery is charging?
    What does the Windows desktop report for the battery status?
    • Kambi13
      • Aug 2022
      • 134
      • Portugal
      No leds come up, just the led in the power brick is flashing. The laptop wont turn on
      • Kambi13
        • Aug 2022
        • 134
        • Portugal
        I do feel the first power mosfet very hot, i've put some IPA on top of it and while is evaporating it's like pulsing the same way the charger light, I've replaced with a new one but the problem remains the same
        • mon2
          • Dec 2019
          • 14255
          Link or post the schematic you are using.
          The fault is often with the 2nd dcin mosfet.
          You can remove it and check if the first mosfet is still hot or not.
          With the 2nd mosfet removed, what is the resistance to ground of the source ? Drain ?
          Best is to first remove all power. Meter in resistance mode.
          Check the resistance across:
          Source & drain
          Source & gate
          Gate & drain
          Pins of each dcin mosfets. Post all measurements. This will confirm if the mosfets are defective or not.
          • Kambi13
            • Aug 2022
            • 134
            • Portugal
            Schematic is for P50-A VGSG-GS Rev21 - wich matches the board here
            Removing the second mosfet will get me 19,4v to the drain of the first mosfet, wich I already tried
            Without the 2nd mosfet in place this is the reading I get in the pads
            Source & drain - 126,5k
            Source & gate - 0
            Gate & drain - 129,7k
            • mon2
              • Dec 2019
              • 14255
              Post the schematic - could only find a BV file in my database.
              These are the readings WITHOUT the mosfet on the board? They are too low.
              Check the same measurements of the mosfet that was removed while it is on your lab bench. What are the measurements?
              What are the resistance readings of the first DCin mosfet?
              Also, when the adapter is attached, what is the gate voltage on the first DCin mosfet? It should be ~25v if the mosfet is passing the adapter voltage through to the 2nd mosfet.
              • Kambi13
                • Aug 2022
                • 134
                • Portugal
                Sorry, I dont have the schematic, only boardview also
                Forgot this is a p-channel mosfet
                Here's the correct readings
                1st Mosfet
                Source & drain - 1,5 ohms
                Source & gate - 231,10 ohms
                Gate & drain - 232,8 ohms
                2nd Mosfet - pads only
                Source & drain - 133,5k
                Source & gate - 240,7 ohms
                Gate & drain - 133,6k
                2nd Mosfet - out
                Source & drain - 12,67M
                Source & gate - OL
                Gate voltage on the first DCin mosfet - 19v
                • mon2
                  • Dec 2019
                  • 14255
                  1st Mosfet
                  These are very low resistance readings. In ohms ?
                  Also, if P-channel, with the gate @ ~19v, the P-channel mosfet should be OFF.
                  The gate should be lower than the voltage the mosfet is passing source/drain.
                  • Kambi13
                    • Aug 2022
                    • 134
                    • Portugal
                    Sorry it's an N-Channel mosfet here's the datasheet (lack of sleep...)
                    • mon2
                      • Dec 2019
                      • 14255
                      Resistance is still low.
                      For N-channel, the gate should be about 6 volts higher than the voltage the mosfet is passing source/drain.
                      What IC is driving these 2 x DCin mosfets ? That will be the charger IC. Is it the BQ type? Post the topside markings from the charger IC.
                      • Kambi13
                        • Aug 2022
                        • 134
                        • Portugal
                        For N-channel, the gate should be about 6 volts higher than the voltage the mosfet is passing source/drain - So true, but that's what it reads - triple checked it
                        Charger IC, yes it's Bq735
                        Here's a pic, those to caps are shorted...
                        • mon2
                          • Dec 2019
                          • 14255
                          See attached. PS: TOPSIDE view.
                          With caution, measure the voltage of the highlighted pins of the charger IC.
                          Red meter probe to pin to test; black to ground.
                          REGN should be 6 volts.
                          ACDRV should be ~25 volts to enable the DCin mosfets. If not this value, power down and locate the ~4k resistor that is often mated to this pin and remove it. Do not lose the resistor but just remove it.
                          Then power up again and check if ACDRV is now ~25 volts.
                          • Kambi13
                            • Aug 2022
                            • 134
                            • Portugal
                            ACDRV - 19,38v
                            ACOK - 1,019v
                            REGN - 6.03V
                            Without the 4k resistor ACDRV, as soon as I touch it with red probe reads 24v and immediately drops down to 19,38v
                            • mon2
                              • Dec 2019
                              • 14255
                              There should be a cap on REGN that is @ 6 volts. This cap is required to keep the charge pump working to deliver the ~25 volts for the ACDRV pin.
                              This cap on REGN may be defective. It is a 2.2uf (or higher) cap (going from memory here) and should be rated at 10V (to be safe) or higher. Perhaps worth replacing as a test.
                              • Kambi13
                                • Aug 2022
                                • 134
                                • Portugal
                                It's 1uf 25V it seems to be ok, took it off and measured it. Maybe it's the actual IC charger that's at fault
                                • mon2
                                  • Dec 2019
                                  • 14255
                                  The issue may be linked to the removed mosfet.
                                  Can you confirm the following measurements?
                                  1st Mosfet
                                  Again - very low resistance readings for source & gate - still this value ?
                                  Source & drain on 1st mosfet is not a good value to have for a good mosfet.
                                  Will check back later..need to buy a suit for junior..
                                  • Kambi13
                                    • Aug 2022
                                    • 134
                                    • Portugal
                                    Same readings. I took out the IC Charger, and i can still see those caps shorting to ground.
                                    After putting back the ic again same values
                                    • Kambi13
                                      • Aug 2022
                                      • 134
                                      • Portugal
                                      Hi mon2, good news I was able to find the problem, it was a SOB of a 10uf cap that was bad in back of motherboard.
                                      Incredible how such a small component can render useless an entire machine...
                                      • mon2
                                        • Dec 2019
                                        • 14255
                                        SOB
                                        Love it! Good job !!
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-12X boardview and Satellite Pro R50-EC-12X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 08:10 PM
