MBP 2020 A2251, 820-01949, 5V 30mA
  • MicroSMD Lab
    • Sep 2018
    • 145
    • Trinidad and Tobago
    This device came in liquid damaged. It was in what seems like a bootloop every 30 seconds with the fans spinning full speed and getting 20V. The liquid damage was only to the Right speaker amp area. I cleaned up, replaced one capacitor and reballed U6550. After that I only get 5V 30mA on all ports. PPBUS_G3H is 0.11V and 13.4ohms to gnd. I get the same voltage readings on all ports
    PP20V_USBC_R_VBUS = 5.19V
    PP3V3_UPC_R_LDO = 3.41V
    PP1V5_UPC_LDO_CORE_R = 1.57V
    PP1V8_SLPS2R = 0V
    PP3V3_G3H_RTC = 0V
    PPHV_INT_G3H_R = 5.18V.
    I read on another post (stated by Piernov) that low ohms on PPBUS_G3H could be short on high side CPU mosfet so I measured around the CPU mosfets and PPBUS_HS_CPU is also 13.4ohms to gnd.
  • mon2
    • 14660
    Re: MBP 2020 A2251, 820-01949, 5V 30mA
    Power down -> remove fuse F7000. Meter in resistance mode.
    Check the resistance on both sides of F7000 SMD pads on the logic board.
    Where is the low resistance to ground ? On the producer side (ISL) or consumer side of PPBUS_G3H rail ?
    If the producer side is no longer a low resistance, power up again and check the voltage of PPBUS_G3H. Post each measurement.
    • MicroSMD Lab
      • Sep 2018
      • 145
      Thanks for the very quick response mon2! The low resistance is on the consumer side (pin 2)... I fear the worst
      • mon2
        • 14660
        After you have removed the fuse F7000, what is the voltage at the start of this fuse pad with the adapter ?
        You are checking the PPBUS_G3H voltage (producer side).
        • MicroSMD Lab
          • Sep 2018
          • 145
          12.29V on producer side
          • mon2
            • 14660
            Do you now see 20V on the power delivery (USB C meter) from your adapter ?
            • MicroSMD Lab
              • Sep 2018
              • 145
              Still 5V but 20mA now, same on all 4 ports
              • Kristion
                Recognising an item on a MacBook Pro 13" 2020 A2251 motherboard
                by Kristion
                Hi there, I had a MacBook Pro 13" 2020 A2251 at work, and it suddenly stopped working without having being bad to it (I ride my bike everyday though). I replaced the motherboard so now it works again, but with other data. I would like to repair the 661-15938 motherboard. I spotted where it burned, I saw that there is a post where there are the 820-01949 pdf and bvr but I don't know what to do with it. I tried to install OpenBoardView because it seems like it's what I should use to have a look at the schematic view of my motherboard. But I failed:
                But surely some people on this...
                08-13-2024, 11:46 AM
                Huawei MateBook 14 2020 Netbook 14 Specification for Upgrade or Repair
                This specification for the Huawei MateBook 14 2020 Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 2020 boardview and 14 2020 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Huawei...
                09-06-2024, 10:20 PM
                Huawei MateBook 14 2020 Notebook 14 Specification for Upgrade or Repair
                This specification for the Huawei MateBook 14 2020 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 2020 boardview and 14 2020 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Huawei...
                09-06-2024, 09:10 PM
                Huawei MateBook 14 2020 Notebook Specification for Upgrade or Repair
                09-06-2024, 08:40 PM
