Acer a315-23 disable ram
  • MisterMG
    • Jun 2022
    • 19
    • Brazil
    Hello friends, how are you? I need your help again, I have an acer notebook (board - DAZ8EMB18A0) that does not post, after analyzing and finding the problem in the onboard memories, is there any way to disable this memory to start? I searched all over the web but I didn't find a way to do this, does anyone know how to help me with this procedure?
    Last edited by SMDFlea; 11-02-2022, 11:40 AM. Reason: copied external images to badcaps
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer a315-23 disable ram
    Do you have schematic+boardview for this motherboard?? Without them its next to impossible to get the job done.
    • MisterMG
      • Jun 2022
      • 19
      • Brazil
      I have an almost identical model, but I'm not yet fully experienced to understand where I should change the board components to be able to disable memory
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        ID0/ID1/ID2/ID3-all needs to be pulled to "1". Mention which ram you have onboard. The pic is not very clear. Post only the RAM ID box which can be viewed properly.
        • JaroTech
          • Mar 2015
          • 351
          You must remove R730 R385 R732 R376 if you have any of these resistors. You must have these resistors on your board R763 R392 R731 R389.
          • MisterMG
            • Jun 2022
            • 19
            • Brazil
            hello friends, follow pictures of the memories on the board, which would be the resistors to remove?
            • MisterMG
              • Jun 2022
              • 19
              • Brazil
              the memories have the serigraphy erased but they are SMART BRAZIL modules
              but i would like to disable them.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                I've already mentioned in post#2 that its impossible to findout the desired resistors unless boardview file is available.
                • MisterMG
                  • Jun 2022
                  • 19
                  • Brazil
                  I only have the schematic, the boardview only found in paid forums
                  code: DA0Z8EMB8C0 is the same board.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Its almost not possible without a boardview.
                    • MisterMG
                      • Jun 2022
                      • 19
                      • Brazil
                      Hello friend! I got the boardview and also made some approximate images of the board, but I still don't know what the next step is, if it is to remove, change or add components?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Try shifting R376 to R389 & R730 to R763
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Not very sure as "Smart Brazil" chip is not even listed in bios. Before shifting take close up photos so that you can revert back to original layout if doesnt works.
                            • 20914
                            The original RAM has probably been replaced with the "smart" ones from an SO-DIMM and the SPD info hasn`t been edited into the bios.There`s no datasheet available for the ram , https://smartmodular.com.br/en/modulos-de-memoria-dram/
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              @smdflea,Perhaps shifting resistors to sodimm only should work even if your doubt is true.Do you too think so or have a different opinion??
                              • mrwab
                                Banned
                                • Jan 2014
                                • 83
                                • morocco
                                upload original bios files i will try to fix you bios to use external memory slot without remove any component from the board
                                • MisterMG
                                  • Jun 2022
                                  • 19
                                  • Brazil
                                  This is original file from acer product page.
                                  https://www.badcaps.net/forum/showpo...04&postcount=9
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Can you explain how you disable onboard ram with bios editing?? I too want to know this technique.
                                      • 20914
                                      The RAM that "SMART Modular" make has these chips - samsung, micron or hynix .Shifting the resistors to the other 3 option might make them work,i don`t know
                                        • 20914
                                        How, do you use AMIBCP .
                                        EDIT: sorry its an Insyde bios,do you use H2OEZE and ifrextract or just a hex editor
                                        • mat2k
                                          Disable faulty soldered RAM on Acer A315-22
                                          by mat2k
                                          Hello, I've been googling for some pointers on this but couldn't find anything that applies to this board. I have an Acer A315-22 (board NB8607) with faulty RAM between 142 and 174mb. I just wanted to disable the onboard RAM altogether, but this one doesn't seem to have any memory down ID resistors or strap in order to disable it. I'm attaching the schematic I found, the boardview for it also seems to be available somewhere in this forum but I still don't have a use for it lol.
                                          How would I disable the RAM on this PC? Thanks for the help.
                                          [MOD EDIT] LINK to boardview + schem...
                                          06-02-2024, 11:26 AM
                                          09-06-2024, 05:27 AM
                                        • b-slayer
                                          Acer A317-53 need help to disable faulty onboard ram
                                          by b-slayer
                                          Hello.
                                          I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                                          - first one is to modify le bios to disable the onboard ram.
                                          - second one is to disable the onboard ram by desoldering some components on the mainboard.
                                          so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                                          so i found that my motherboard...
                                          10-12-2024, 03:46 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
