A551L no signal and fickering
  • ale211734
    • Oct 2022
    • 4
    • Italy
    I have a issue with asus A551L laptop.
    Lcd came black some time when I streaming a movie and the audio and backlight work. When lcd is black if I connect the laptop to external monitor I can see a correct image, it's work.
    Sometime after that screen became black, I can see a flickering white image.
    I captured a video showing the problem video
    Any idea?
    Thanks in advance.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: A551L no signal and fickering
    It flickers only on battery power or flickers on both adapter/battery?? Measure LVDS/EDP connector pin voltages.
    • ale211734
      • Oct 2022
      • 4
      • Italy
      thanks for reply,
      the problem is present with only the battery connected and when I connect the laptop with power supply. Today I connect it with power supply I get a only one black screen without flickering.
      Sorry I am a beginner, can you explain how check LVDS/EDP connector?
      Can you explain me how check the voltage on the connector. I just open the lcd. Should I check the voltage on pcb components connect to pins of lcd connector (red arrows in image attachment)? I don't know the pinout.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        There is a coil marked 100 on led logic card. Replace it with same coil from any other bad screen . This is a common fault with asus. This should fix screen flickering on battery only.
        Lets fix this part first. Then we can proceed further.
        Btw, have you tried another known good screen?? Attach boardview file ,if available.
        • ale211734
          • Oct 2022
          • 4
          • Italy
          It has been several days since the last time the screen went black and flashed after I disassembled and removed the LCD cover and disconnected and reconnected the cable from the side of the screen several times. Could it be some contact on the cable?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Yes it can be.
            • cjard
              Dell U27HM flickering/quarter image/black with smeared colors
              by cjard
              Hi all
              Wondering if I could get some insight on a Dell U27HM. First turned it on and the image was completely black. I later realised that if I dragged a window from one monitor to (the broken) other one then smeared colors would appear on the bottom 75% of the screen. After being on for several hours the top part of the screen started flickering showing an image (I have a video of this) and then suddenly the image appeared albeit rather fuzzy in the bottom 75% - image attached - and some hour later it now appears normal
              I do have two of these monitors so a compare/swap...
              09-13-2022, 07:12 AM
              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-12-2024, 02:20 PM
            • AstutePauciloquent
              Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
              by AstutePauciloquent
              Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
              I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
              11-23-2023, 11:02 PM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
            • Jaime Morillo
              Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
              by Jaime Morillo
              Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
              The TV was stuck on the logo and I couldn't access the update menu.
              I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
              The image result was good, but the image is inverted.
              The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
              Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
              08-18-2025, 11:38 AM
