HP Pavilion x360 Brittle MB 15256-1 0.7V on RAM
  • REpairAT
    • Nov 2020
    • 143
    • Austria
    notebook was water damaged, powercycled all two seconds.
    Found oxidation around RT8231AGQW IC, desoldered, cleaned, all pads are fine (on board and IC). found resistor on Pin 9 (TON) open, replaced it with 500k, now notebook stays on but delivers only 0.7V on RAM.
    How to properly check if the chip itself is fine or cause of the issue? Couldn't find any schematic either.
    Thanks a lot!
    BR, Ray
  • mon2
    • Dec 2019
    • 14368
    Re: HP Pavilion x360 Brittle MB 15256-1 0.7V on RAM
    Study the other HP logic boards that use the 'B' (without tracking support) version of the same component.
    • REpairAT
      • Nov 2020
      • 143
      • Austria
      "PR222" 243k on Pin 13 (CS) measures 434k on my board, rest seems normal.
      • mon2
        • Dec 2019
        • 14368
        Pin 13 defines the current limit which may be fine and is by design of this logic board.
        Is the RAM soldered on this board or removable?
        • REpairAT
          • Nov 2020
          • 143
          • Austria
          Removable. With RAM, static 0.7V
          Without, notebook powercycles few times with a peak of around 2.6V on on RAM slot. As soon as it stays on, 0V.
          • mon2
            • Dec 2019
            • 14368
            Is the RAM the original and compatible module for this unit?
            The output voltage for the RAM sounds high but not sure so wait on additional feedback.
            Consider to replace this component and test without any ram after the component has been replaced.
            • REpairAT
              • Nov 2020
              • 143
              • Austria
              Thanks!
              Yes, RAM is original and known good, also doesn't work with two other same spec modules.
