NO POWER HP Pavilion Gaming 15-ec0013dx
  • savemydevice27
    • Nov 2021
    • 15
    NO POWER HP Pavilion Gaming 15-ec0013dx after prior attempt at battery replacement. Customer stated they slipped with a screw driver shorted a component out near battery connector and caused a spark.
    Poked around with meter and found a short on the source legs on B20N03 mosfet (image attached). Mosfet looked a little burnt so I pulled but short remains on source. Looking for schematics or help further diagnosing.
    Motherboard info: DA0G3HMB8D0 rev: D
    Model : G3HA
  • mon2
    • 13829
    Re: NO POWER HP Pavilion Gaming 15-ec0013dx
    The source pins = pin # 1, #2 and #3 are grouped together so they will appear as a short. You can review the bottom side of the same part and there will be a thick grouped trace across these 3 pins.
    Likewise, the drain will feature pin # 5, #6, #7 and #8 to be grouped together.
    This is done to spread the current across multiple contact pins ('sharing the burden').
    You can check if the mosfet is truly defective by reviewing the resistance across the mosfet pins:
    < remove all power; no battery & no power adapter >
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    reference:
    http://electronicsbeliever.com/how-t...0good%20MOSFET.
    see the resistance method of testing at the above webpage.
    • savemydevice27
      • Nov 2021
      • 15
      No, all source pins 123 are short to ground. I don't think that's normal. I may be wrong though.
      • mon2
        • 13829
        Can you link the schematic, if you have it?
        The source may be truly connected to ground. This mosfet could be the low side mosfet of a power rail.
        What is the exact resistance reading? Short your probes on the meter, same reading?
        • savemydevice27
          • Nov 2021
          • 15
          Yes, 0 ohms of resistance in diode mode. And I don't have schematics unfortunately.
          • Sephir0th
            • Oct 2020
            • 1246
            Also in my opinion that's just a normal buck converter with of course one MOSFET connected to GND. Source of the MOSFET in question is connected to GND while Source of the other MOSFET is connected to Phase is another indicator.
            With the zoomed in picture of the initial post nobody can do anything. And really, if you continue with the hunt for bad low-side MOSFETs it might went to be a endless repair attempt.
            Share resistance to GND of each Coil and the main power rail (at CSR) instead if you want to make progress.
            FairRepair on YouTube
            • savemydevice27
              • Nov 2021
              • 15
              Not to sure where to measure. I typically do iphones only. Trying to expand. Thanks for help. Let me know if any of that helps. =)
              • savemydevice27
                • Nov 2021
                • 15
                picture attached.
                • savemydevice27
                  • Nov 2021
                  • 15
                  Update on BQ
                  • mon2
                    • 13829
                    Post pics of where the external power adapter powers this logic board -> nearby will be 2 x DCin mosfets. They are of interest.
                    • savemydevice27
                      • Nov 2021
                      • 15
                      charger charges laptop via a cable that runs to the MB. Here is the backside of where the cable connects to.
                      • savemydevice27
                        • Nov 2021
                        • 15
                        here is what i mean
                        • mon2
                          • 13829
                          When you power these boards with the proper external power adapter, are you able to measure any voltage on any of these mosfets?
                          The 2 x mosfets near the battery connector will be the HIGH & LOW side mosfets that charge the battery.
                          Before this can even happen, the BQ charger IC needs to be powered.
                          Respectively, locate where the DC adapter connector is located -> the 2 x mosfets in this region are of interest.
                          After these 2 x mosfets will be the BQ charger IC.
                          Post pics of the DC adapter connector and region.
                          You show mosfets on BOTH sides of the PCB -> check which ones are connecting to the DC adapter connector.
                          Update - ok - see you holding the adapter connector. This is new to me.
                          Now confirm that the mosfets nearby are connecting to the white nylon connector with a resistance check.
                          • savemydevice27
                            • Nov 2021
                            • 15
                            The 19v dc connector from charger is working correctly. Have 19v on the diode. I have continuity from the red side of the dc in to the back mosfets pictured.
                            • mon2
                              • 13829
                              Ok. Remove all power. Meter in resistance mode. Follow the suggestions in post #2 to check the resistance across the same mosfet pins.
                              Post each measurement and the meter scale used for the resistance checks.
                              So for example, source (1-2-3) & drain (5-6-7-8) - what is the resistance?
                              Interested in the readings of both mosfets.
                              • savemydevice27
                                • Nov 2021
                                • 15
                                Okay so this is new testing to me, but I think I understand.
                                Top mosfet with meter in diode mode
                                Red probe on source and black on drain is .668
                                Black probe on source and red on drain is open
                                Red probe on source and black on gate .478
                                Red probe on drain and black on gate its open, then if I put red probe back on source its opened (short to ground.)
                                Bottom mosfet with meter in diode mode
                                Both performing the same.
                                • mon2
                                  • 13829
                                  Actually, no. Meter in resistance mode. You should see the greek symbol (omega for ohms).
                                  Then perform your testing.
                                  So one meter probe (either color) on source pins (1-2-3) - pick anyone.
                                  Other meter probe to drain pins (5-6-7-8) - pick anyone.
                                  Record the RESISTANCE. Out of habit, just learned with resistance checks.
                                  Post each measurement. No power during these tests on the logic board !!
                                  Do also post the meter scale used during these tests.
                                  • savemydevice27
                                    • Nov 2021
                                    • 15
                                    Aright thanks for clarification.
                                    I have my meter in ohms mode on the 200m setting. Lower settings (20m/200k/20k didn't show any reading.)
                                    Top mosfet
                                    Black probe on drain and red on source I get 1.1. Reverse probes it shows reading for 2 seconds as it climbs rapidly to OL. (15, 40, 80, 150)
                                    Bottom mosfet
                                    • savemydevice27
                                      • Nov 2021
                                      • 15
                                      Hopefully that helps
                                        09-06-2024, 05:59 AM
                                        HP Pavilion Power 580-071na Pavilion Power i5-7400 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Power 580-071na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-071na boardview and Pavilion Power 580-071na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-12-2024, 02:00 PM
                                      • Tynan Dill
                                        by Tynan Dill
                                        Assuming...
                                        11-22-2024, 01:46 PM
                                      • Thomas Smith
                                        Asus Tuf gaming fx506l no power, mosfet does not open
                                        by Thomas Smith
                                        Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
                                        Initial Symptoms:
                                        • The laptop has no power at all (no LEDs, no fan spin).
                                        • No 3.3V or 5V present on the board.
                                        • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
                                        Power Rail Checks:
                                        1. Charger input (FETs PKCH2BB)
                                          • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
                                        2. BQ24780S Charger IC:
                                          • VCC and ACDET are present.
                                          • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
                                          • Shunt resistor has 10Ω to ground.
                                        03-30-2025, 03:38 AM
                                        HP Pavilion Power 15-cb094tx Notebook 15 Specification for Upgrade or Repair
                                        This specification for the HP Pavilion Power 15-cb094tx Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Power 15-cb094tx boardview and Power 15-cb094tx schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 05:54 AM
