Acer AN515-54 won't power on, charger light comes on
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    hi I have the above acer laptop.
    I have the schematic and board view files.
    but I can figure this out,
    when I connect the charger it shows charging on the charge light,
    but PL301 gets red hot within a few seconds so I cut the power.
    and I think its shorted to ground,
    can anyone help me solve this issue ?
    thanks
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 209
    Re: Acer AN515-54 won't power on, charger light comes on
    ok after disconnecting the battery PL301 no longer heats up.
    im getting voltage on the following components
    PUZ2 PUZ3 PUZ4 PUZ5 PQB11 PQB12 all reading 19v
    anyone able to help ?
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
    • jasonr2000
      Advance Tech
      • Nov 2013
      • 209
      ive now discovered that PU301 is getting extremely hot but then going cold so it must be turning off ???
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
      • Sephir0th
        • Oct 2020
        • 1282
        You neither shared the boardnumber nor measurements to confirm a short to GND somewhere. How do you think anyone can help you out then (with literally no informations shared).
        At least your main power rail seems fine. In the meantime I'll try to find out what is PU301 and what is controlled by it.
        FairRepair on YouTube
        • Sephir0th
          • Oct 2020
          • 1282
          Check resistance to GND of +3VL and +3VALW
          • jasonr2000
            Advance Tech
            • Nov 2013
            • 209
            Hi sorry I forgot to add that info.
            I will test what you have said and post back my findings.
            Samsung UE46D6530
            Samsung BD-F7500
            Samsung HT-ES6200
            • jasonr2000
              Advance Tech
              • Nov 2013
              • 209
              hi again
              the +3VALW is 0 ohm
              the +3VL is 0 ohm
              board number is LA-H501P
              Samsung UE46D6530
              Samsung BD-F7500
              Samsung HT-ES6200
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                You will need a dc supply to proceed further as voltage needs to be injected on +3VL line to findout what is shorted. Very likely a shorted KBC and/or shorted PCH part of SOC. The voltage injection should'nt exceed 1V.
                • jasonr2000
                  Advance Tech
                  • Nov 2013
                  • 209
                  ok where would I tap it on to ?
                  ive never done voltage injection before (sorry)
                  Samsung UE46D6530
                  Samsung BD-F7500
                  Samsung HT-ES6200
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    On +3VL
                    • jasonr2000
                      Advance Tech
                      • Nov 2013
                      • 209
                      hi guys sorry for my very late reply I had to wait on my DC power supply to arrive and it took longer than planned
                      how much voltage should I inject and amps ?
                      Samsung UE46D6530
                      Samsung BD-F7500
                      Samsung HT-ES6200
                      • mon2
                        • 14112
                        Personally use 0v8 (0.8 volts) with our 30A 'short killer' device. Has worked well to date.
                        Recommend that you start @ 0v8 on the voltage and consider 2-3A on the current.
                        Red probe on the +3VL line. Black to ground. Your power supply should display that a large amount of current is being consumed by the short on the logic board. Respectively, some part should be heating up during this procedure. Hope that it is not the PCH / CPU which is a complex BGA device to replace.
                        You can pour IPA (alcohol from Costco; pharmacy grade is great for the job) over the group of parts you suspect to be shorted. Even better if you have a thermal camera.
                        The IPA will mist away if it is the heated component. Often, caps are causing the short internally and they must be removed / replaced.
                        • isa198585
                          • Feb 2020
                          • 71
                          • austria
                          try removing both fans
                          • jasonr2000
                            Advance Tech
                            • Nov 2013
                            • 209
                            hi ive tried that
                            and its still dead as a dodo but it does charge the battery ??
                            Samsung UE46D6530
                            Samsung BD-F7500
                            Samsung HT-ES6200
                            • jasonr2000
                              Advance Tech
                              • Nov 2013
                              • 209
                              hi again ive found the part that is heating up
                              its an ic PU301 could it be heating because if bad capacitors ??
                              Samsung UE46D6530
                              Samsung BD-F7500
                              Samsung HT-ES6200
                              • mon2
                                • 14112
                                Yes, it could be or another part - as per post #8.
                                Keep the voltage under 1 volt to be safe.
                                Then apply onto this line that is shorted with 0 ohms.
                                Who is heating up under this setup of voltage injection ?
                                • jasonr2000
                                  Advance Tech
                                  • Nov 2013
                                  • 209
                                  hi again
                                  ive just started to test at 0.8v at 2 amps and its drawing 0.5w and nothing is heating up now
                                  Samsung UE46D6530
                                  Samsung BD-F7500
                                  Samsung HT-ES6200
                                  • jasonr2000
                                    Advance Tech
                                    • Nov 2013
                                    • 209
                                    ok ive done further testing and the PCH is heating up with a 0.8 v injection on the +3VAL line
                                    Samsung UE46D6530
                                    Samsung BD-F7500
                                    Samsung HT-ES6200
                                    • mon2
                                      • 14112
                                      Wait on others to comment but appears your CPU is dead.
                                      • jasonr2000
                                        Advance Tech
                                        • Nov 2013
                                        • 209
                                        thanks its odd that the CPU would die randomly like it has the only thing I had to do was drill out a screw that held the case on and then it was dead.
                                        but thank you for all the help so far.
                                        Jason
                                        Samsung UE46D6530
                                        Samsung BD-F7500
                                        Samsung HT-ES6200
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
