Asus FX86F freeze with Charger
  • salawayon
    • Nov 2012
    • 568
    • philippines
    help needed on this unit. it freeze when charger is being inserted. but with just the main battery only it works normal. with charger inserted at bootup it will end up in BSOD. i tried already flashing the bios... thanks
  • mon2
    • Dec 2019
    • 14146
    Re: Asus FX86F freeze with Charger
    Check the usual 2 x DCin mosfets that follow the DCin power adapter connector.
    If you have schematics for this unit, link or post them here.
    If not (have not checked my database of schematics), locate the DCin connector and search for the usual 8 pin (small black square looking package) mosfets.
    Post clear pictures here for a review. You can check the status of these mosfets by removing all power (NO BATTERY either) and check the resistance across the mosfet pins.
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Post each measurement and also the scale used on your meter.
    • salawayon
      • Nov 2012
      • 568
      • philippines
      i already replaced those two mosfets before posting here.
      original mosfets - 4511NH
      replaced with - MDU1516 and MDU1511
      got same unit but it uses AO6414A mosfet.
      • mon2
        • Dec 2019
        • 14146
        The MDU and AO parts are N-channel (single) and appear to be fine for replacements.
        So far, unable to locate the datasheet for the 4511NH mosfet. Your logic board is 100% identical that uses the AO ?
        Check the voltage on each pin of each mosfet:
        source (1-2-3)
        gate (4)
        drain (5-6-7-8)
        with the adapter connected. Being N-channel, the gate voltage is expected to be ~25v to enable the respective mosfet.
        Update - forgot to ask - what is the charger IC on this logic board? It should be nearby. Perhaps the TI ('BQ') series ??
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Does it uses NEC-Tokin caps on cpu vcore circuit??
          • salawayon
            • Nov 2012
            • 568
            • philippines
            source (1-2-3)
            gate (4)
            drain (5-6-7-8)
            @mdu1516:
            source - 19.85v
            gate - 24.92v
            drain - 19.85v
            @mdu1511:
            source - 19.84v
            gate - 24.93v
            drain - 19.84v
            it uses BQ24780s as charging IC.
            • salawayon
              • Nov 2012
              • 568
              • philippines
              it doesn't have a NEC-TOKIN Caps
              • mon2
                • Dec 2019
                • 14146
                These are good readings. Locate the other mosfets mated with the same charger IC. Need to check the resistance of their pins to be sure they are not defective.
                Review the battery mosfet, which may be leaking.
                • salawayon
                  • Nov 2012
                  • 568
                  • philippines
                  schematics and boardview:
                  https://www.badcaps.net/forum/showth...hlight=FX505GD
                  • mon2
                    • Dec 2019
                    • 14146
                    Excellent. Thanks for the link.
                    Review the resistance of Q8800.
                    Remove all power and no battery before taking measurements.
                    • salawayon
                      • Nov 2012
                      • 568
                      • philippines
                      @Q8800 resistance with respect to ground.
                      drain - 1.5Mohms
                      gate - 638Kohms
                      source - 3.4Mohms
                      voltages @Q8800:
                      ON BATTERY:
                      source - 11.94v
                      gate - 8.04v
                      drain - 11.94v
                      ON CHARGER ALONE:
                      source - 12.67v
                      gate - 12.66v
                      drain - 19.96v
                      WITH BATTERY and CHARGER connected:
                      source - 12.92v
                      gate - 12.62v
                      drain - 19.72v
                      • mon2
                        • Dec 2019
                        • 14146
                        Resistance check, not to ground but across the mosfet pins.
                        From post #2
                        • salawayon
                          • Nov 2012
                          • 568
                          • philippines
                          sorry for that... i used FLUKE 75 multimeter...
                          * with mosfet removed from board all resistance reading were infinite...
                          * with mosfet while onboard:
                          source-drain = 262Kohms
                          source-gate = 1.7Mohms
                          gate-drain = 2Mohms
                          • mon2
                            • Dec 2019
                            • 14146
                            With this battery mosfet removed, does the charger continue to power the logic board properly? That is with NO freezing if using only the power adapter?
                            Removing the battery mosfet will remove the battery as a power source from the equation unless the high side mosfet of the charger is leaking.
                            • salawayon
                              • Nov 2012
                              • 568
                              • philippines
                              without Q8800 mosfet:
                              - on battery alone the unit is ok.
                              - with charger alone unit is working but it freeze at startup
                              - on battery at normal startup but when charger is being used it freeze
                              • mon2
                                • Dec 2019
                                • 14146
                                With battery alone, the battery mosfet Q8800 is removed but the logic board works??
                                If yes, replace the high side charger mosfet as it must be leaking. Check the resistance like before of the high side mosfet. No battery or adapter during these checks.
                                With Q8800 removed, the logic board should not be powering up with only the battery.
