mac 820-00165a no power on
  • reset1986
    • 308
    • italia
    hi all, I got this motherboard that initially gave no signs of life, no magsafe light, I was missing P3V3_S5_REG_L, because no signal P3V3S5_EN_R
    reballato smc the macbook came back to life, the next day it came back with the same symptom no sign of life and P3V3_S5_REG_L P3V3S5_EN_R
    missing
    L7130 and 8.12v
    L7095 G3h 3.42V
    SMC_BC_ACOK 3.30 V
    PM_SLP_S5_L 0V
    PP5V_S5 0V
    SMC_PM_G2_EN 0V
    PPBUS_S5_HS_OTHER_ISNS 8.12
    P5VP3V3_VREG3 3.40
    now I have no light on magsafe, wearily sometimes the light is there, the fan starts for 10 seconds and stops
    possible smc failure?
  • mon2
    • Dec 2019
    • 14672
    Re: mac 820-00165a no power on
    No light on magsafe means you do not have 3v42?
    Can you confirm it?
    • reset1986
      • 308
      • italia
      Can you confirm it?
      PP3V42_G3H always at 3.42
      almost always no light, sometimes the light returns to the green magsafe, but it does not start
      • mon2
        • Dec 2019
        • 14672
        After the fan stops, does it turn ON again and power cycle in a loop ?
        When the magsafe light is off - what is the PPBUS_G3H voltage ?
        Does PPBUS_G3H power cycle ?
        • reset1986
          • 308
          • italia
          now I get magsafe green steady light, sometimes it remains spent, however there is no fan rotation, PPBUS_G3H fixed at 8.12V
          all tests without battery
          even without green light I get 8.12V
          • reformatt
            • Feb 2020
            • 1506
            SMC isn't running. Check the usual suspects, J6100 for crap, crap around SMC reset cct U5110, check for SMC_RESET_L and PP3V3_S5_AVREF_SMC at the SMC itself etc. If all good, then check Y5110 to see if it's biased and there is a clock.
            Sometimes weird shit on these boards is crap under a BGA and ultrasonic fixes it.
            • reset1986
              • 308
              • italia
              clean motherboard, measured u5110
              SMC_RESET_L 1.20 V
              SMC_LSOC_RST_L 3.3v
              SMC_ONOFF_L 3.3v
              PP3V3_S5_AVREF_SMC 3.3v
              SMC_MANUAL_RST_L 2.7v
              PP3V42_G3H_SMC_SPVSR 3.42
              PP3V42_G3H 3.42v
              • reformatt
                • Feb 2020
                • 1506
                SMC_RESET_L initially gets pulled low by U5100, but then should be pulled to 3.3V by R5100, so 1.2V isn't right. Check the resistance on this line, clean J6100 with IPA and toothbrush. You can remove U5100 to see if it comes up to 3.3V as well.
                • reset1986
                  • 308
                  • italia
                  u5100 is not present, I have u5110, unsoldering u5110 I always have low 0.8 / 1V SMC_RESET_L
                  the resistance is high there are no dispersions,
                  also unsoldered R7100 to check if SMC_RESET_L returned high but does not change
                  R5100 at around 90Koms is ok
                  I think of a broken smc, do you think?
                  • reformatt
                    • Feb 2020
                    • 1506
                    Sorry meant U5110. Without that installed, SMC_RESET_L should be 3.3V (pulled up by R5100). First ensure that the pads underneath R5100 are ok (sometimes these are corroded and not making a good connection with liquid damage). You've isolated the ISL chip, so the only other places are J6100 or the SMC itself. Eliminate any issues with J6100 first then try a reflow of the SMC.
                    • reset1986
                      • 308
                      • italia
                      The smc was reballed as the first operation, but it does not change, to replace the smc it is necessary to take from an identical card?
                      • reformatt
                        • Feb 2020
                        • 1506
                        So if you remove the SMC, does your reset line now measure 3.42V? PP3V42_G3H is independant of the SMC, so should still be active regardless of whether the SMC is on the board. If that measures correct with the SMC off the board, consider to replace it (or look at your flux/soldering of the SMC itself).
                        You can now use a 820-3437 SMC on a 820-00165 board and reprogram the firmware. There is a tool on Github to do that, only requirement is that the board still has to boot. I've tested it successfully with a 3437 SMC on a 00165 board and it works great. Good option as there are plenty of crappy 3437 1.4G 4G boards out there for parts.
                        https://github.com/MuertoGB/SMCTool
                        • reset1986
                          • 308
                          • italia
                          I remove smc and see if it withdraws the reset line up, in the case of reprogramming firmware with programmer, is there a guide?
                          • reset1986
                            • 308
                            • italia
                            ok, i have smc and the reset line is back to 3.30v, i will have to look for a compatible smc
                            • dellxps15
                              • Feb 2014
                              • 1598
                              • italy
                              smc was soldered properly ?
                              • reset1986
                                • 308
                                • italia
                                I think so, when cold the mac started for 20 seconds then turned off
                                • reformatt
                                  • Feb 2020
                                  • 1506
                                  All of the info needed is on the Github page. You can also refer to Paul Daniels YouTube video on it. The board has to be able to boot with the donor SMC in order to reprogram it.
                                  https://youtu.be/q8LEh8C4iYo
                                  Also make sure you are using a good quality no clean flux.
                                  • phamthai2503
                                    • Dec 2015
                                    • 4
                                    • Viet Nam
                                    May I ask if the repair process is that you removed the faulty SMC from the Mainboard 820-00165, then took the SMC from the Mainboard 820-3437 and made the ball pins and installed it on the Mainboard 820-00165, plugged in the USB with SMCTool. Turn on the Mainboard 820-00165, display the Boot Menu, select USB SMCTool ...
                                    Now, I only know that the SMC on the Mainboard 820-3437 vs 820-00165 can be interchanged as you said
                                    how to find information interchangeably in different circuit boards?
                                    thank you!
                                      Lithonia Lighting versus Light of America Compact Fluorescent product quality
                                      by sam_sam_sam
                                      I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                                      I also have back when Light of America had these light bulbs available for yard lights
                                      The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                                      While the Lithonia lighting fixture has all most certain bulb failure
                                      So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                                      I have only had this light fixture for not more than a year if it...
                                      07-02-2023, 03:45 PM
                                      LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 03:40 AM
                                      LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                      This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 09:10 PM
                                      09-06-2024, 08:40 PM
                                    • serious_electron
                                      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                      by serious_electron
                                      Hello Everyone!
                                      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                      06-28-2025, 02:57 PM
