HP 15-AX205NS, does not turn on with original charger
  • vevemar
    • May 2016
    • 10
    • España
    Hello colleagues, I ask for help with an HP 15-ax205ns, with a DAG35DMBADO Rev board which only starts with the power supply and with a universal charger, but with the original charger nothing, the id light comes on but it does not start, and that's it I have tried it with another original from Hp and neither.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 15-AX205NS, no enciende con cargador original
    AD_ID voltage??
    • vevemar
      • May 2016
      • 10
      • España
      603 mv with original charger
      1.08 V with power supply
      • mon2
        • 13938
        Re: HP 15-AX205NS, does not turn on with original charger
        What is the actual voltage from the original charger ?
        What is the voltage used from your power supply that is working for your logic board ?
        • vevemar
          • May 2016
          • 10
          • España
          19 v
          • mon2
            • 13938
            The voltage of AD_ID will vary based on the power (current) that can be supported by the external power adapter.
            Your external lab power supply works but is based on a different AD_ID value. This higher AD_ID announces to the logic board that the power supply is capable of powering the logic board.
            The lower AD_ID is not suitable so the logic board will remain off.
            Check against the specs from the HP datasheet for this laptop, what is the recommended power adapter and compare to the one that you are using.
            Either way, the AD_ID has to be higher to function.
