latitude e7450 la-a961p
  • aminealae
    • Jun 2013
    • 97
    • morocco
    Originally posted by qayyum786
    1} Replace "PR9" 33 ohms resistor ( most common cause)
    2} After That Replace PU111
    3} If you dont have PU111 Than
    remove "PU111" and bypass by jumper from pin 3 to 4
    Hopefully one of this solve the issue
    hello bro i have latitude e7450
    la-a961p the laptop turn on normally without battery but on battery on board the PD5 burn if you have any idea
    [MOD EDIT]
    Schematic - https://www.badcaps.net/forum/showthread.php?t=73364
  • mon2
    • 14592
    Re: DELL E7440 LA-9591P doesn't detect charger
    What are the details of the part you are placing at PD5 ?
    PESD5V0U2BT is being soldered ?
    • aminealae
      • Jun 2013
      • 97
      • morocco
      Re: latitude e7450 la-a961p
      Azc199-02spr7g
      • mon2
        • 14592
        With no part @ PD5, what is the voltage that you are measuring on PL3, pin # 1 ?
        • aminealae
          • Jun 2013
          • 97
          • morocco
          PL3, pin 1 5v
          • mon2
            • 14592
            It is very strange if a known good ESD diode @ PD5 is burning up.
            According to the datasheet, the part is suitable for USB 2.0 and similar interfaces so 5 volts is an ok voltage.
            Do you have a trusted vendor / source for this replacement part ? Or was it from a donor board ?
            • aminealae
              • Jun 2013
              • 97
              • morocco
              original board
              • aminealae
                • Jun 2013
                • 97
                • morocco
                can you tell me if i want to cancel battery what component i need to remove ???
                • aminealae
                  • Jun 2013
                  • 97
                  • morocco
                  Prp2
                  • mon2
                    • 14592
                    PRP2 = current limit resistor network applied in series. If it is removed, the signals from the battery connector will be removed from the logic board.
                    Here is a suggestion to try:
                    1) Do not stuff the diode @ PD5 (for now).
                    2) Remove PQ2 mosfet. Now apply the external power adapter connector and measure the voltage on each pin of PQ2. Post the readings.
                    Do you still have 5 volts on the PS_ID pin ?
                    PQ2 is acting like a switch to allow / stop the single wire communication line from the external power adapter to the logic board. We want to remove this part to determine the true voltage of the PS_ID pin.
                    • aminealae
                      • Jun 2013
                      • 97
                      • morocco
                      on PQ2
                      pin 1 5v
                      pin 2 5v
                      pin 3 3.3v
                      • mon2
                        • 14592
                        Aside from burning PD5, does the adapter actually charge the battery ?
                        Can you boot normally if the battery and adapter are connected ?
                        Does Windows report that the battery is found and is charging ?
                        The issue may be linked to a defective mosfet from the DC adapter side - worth to test the first 2 mosfets with no power. Meter in resistance mode.
                        Check the resistance across the mosfet @ PQ4:
                        source & drain
                        source & gate
                        gate & drain
                        then also check the next mosfet @ PQ700.
                        Post all resistance measurements.
                        • aminealae
                          • Jun 2013
                          • 97
                          • morocco
                          source & drain
                          source & gate
                          gate & drain
                          thank you for all
                          i have changed charger adaptor now the PD5 not burn but the laptop is very slow (bios + windows) and no detect battery
                            • 21479
                            Originally posted by aminealae
                            thank you for all
                            Its best to always use a genuine charger of the same or higher wattage. What was the charger you used previously,was it a HP one
                            • aminealae
                              • Jun 2013
                              • 97
                              • morocco
                              yes HP . now i use a genuine dell adapter but laptop is very slow bios and windows
                                • 21479
                                HP chargers should never be used to power dells.The E7450 requires a 65W adapter.
                                • aminealae
                                  • Jun 2013
                                  • 97
                                  • morocco
                                  I use it now but same problm slow and battery not detected
                                  • mon2
                                    • 14592
                                    I think that you still have mosfet PQ2 removed from the logic board ?
                                    This is the switch to allow the logic board to detect the power adapter.
                                    By default, if the adapter is not detected or is detected but is a lower power adapter, then the logic board will slow down.
                                    Install back PQ2 and test again. Confirm that the power adapter is 100% the proper rated power for this machine.
                                      DELL Latitude E7450 Notebook 7000 Specification for Upgrade or Repair
                                      This specification for the DELL Latitude E7450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7450 boardview and E7450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                                      09-06-2024, 04:40 PM
                                      09-06-2024, 04:10 PM
