DELL E7440 LA-9591P doesn't detect charger
  • Conste
    • Oct 2018
    • 235
    Dear all,
    I have a DELL E7440 which does not detect charger ID.
    1. I have tried different chargers which work fine on my E7450 and are correctly detected.
    2. Also tried different batteries.
    3. I tried charging using the power dock in the office, which also won't make the unit detect the charger.
    4. EC and MAIN were flashed with good known dumps from badcaps
    What to do next?
    Manual can be found here:
    https://cdn.badcaps-static.com/pdfs/...2fcb0f0446.pdf
    Could it be PU111? (page 41 should be the circuit).
    Thanks in advance.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: DELL E7440 LA-9591P doesn't detect charger
    voltage on PQ2 all pins Yep ma be PU111 volatge on all pin PU111 ?
    • Conste
      • Oct 2018
      • 235
      Voltage on Pin 1 and 3 of PQ2 is 0,33 volts, so not enough. Should be 3,3 I guess?
      One Pin on PU111 is burned and gone, guess I have to replace this one first?
      Or shall I desolder PU111 and see if it goes up to 3,3 volts?
      • Techtiger
        • Oct 2014
        • 1602
        • france
        desolder PU111 & see
        • qayyum786
          • Aug 2018
          • 1957
          • INDIA
          1} Replace "PR9" 33 ohms resistor ( most common cause)
          2} After That Replace PU111
          3} If you dont have PU111 Than
          remove "PU111" and bypass by jumper from pin 3 to 4
          Hopefully one of this solve the issue
          • Conste
            • Oct 2018
            • 235
            After desoldering PU111 I had 3,3 volts. Then I put a small wire between Pin 3 & 4.
            Battery is charging, adapter is correctly detected.
            Thank you techtiger and qayyum786
            • godit3
              chrisTech
              • Nov 2015
              • 29
              • ghana
              i strongly believe u will be the next Bill gates....wow it worked like magic
              • Adebeebs
                • Feb 2018
                • 7
                • Nigeria
                Thank you so much
                This solve my problem
                • motormayhem
                  Lenovo T460 Only Charges on One Charger
                  by motormayhem
                  Laptop Question
                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                  05-12-2023, 01:46 PM
                  DELL Latitude E7440 Ultrabook 7000 Specification for Upgrade or Repair
                  This specification for the DELL Latitude E7440 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7440 boardview and E7440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                  09-06-2024, 04:40 PM
                  09-06-2024, 04:10 PM
                • coasterghost
                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                  by coasterghost
                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                  System Hardware:
                  Processor: AMD Ryzen 7 PRO 5850U
                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                  09-08-2025, 10:46 PM
