Acer 5100 errors out cant load os but can boot from cd...
    At post I get the following error message
    Bus:06 Device:02 Function:00 ERROR
    Resource Conflict - PCI in slot 03 Bus:06 Device:04 Function:00 through 04 individual messages of course.
    I removed only thing connected on that bus wireless card did not resolve the problem.
    Set bios defaults Problem not resolved
    Updated bios Problem not resolved
    Tried to install an OS with no luck.
    Ran bootable discs in DrDos without issues as well ...
    I am curious if anyone out there has found and fixed this issue before or maybe someone could tell me where and what to look for eg. common issues...
    Thank you folks out there for taking your time to at least read my post weather you divulge the info or have it to do so or not I realize that you are not getting paid to assist me at my every beckoning call but I do appreciate any help or direction I get on this form even if it is taking the simple time to read it that is still in my mind an attempt at improving my situation and done so without reward.
    Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
    Re: Acer 5100 errors out cant load os but can boot from cd...
    try this here may or may not help
    http://www.help2go.com/forum/compute...ing-issue.html
      This issue was mentioned on the site above however it was not resolved. This is not looking like a software issue at all but as HARD hardware failure. Was there anything done recently that brought on this problem? If so, reverse coarse. If not - motherboard.
        Known Issue: 3100/5100 Acer Motherboard
        Culprit: South Bridge
        Most Common Error Message: Error 200
        Conclusion: All PCI devices run through the south bridge of the motherboard.
        Action: Preform the same rework as done for an error 200.
        Video: http://www.youtube.com/watch?v=47PdJ5FWsQQ
        Results: Unknown, have not attempted.
        Preventative Solutions: <Insert your ideas here>
          damn.. so it's a flexing issue just like the infamous Thinkpad T40 - T43 had..
            turned out it was the ATI chip on top of the board
              it's necessary to change SB 460
              JOVY RE7500
