Alienware m15 R4 with GPU NVIDIA GeForce RTX 3070
  • sikocan
    • Oct 2019
    • 344
    Hello there, I've got an Alienware m15 R4 with the GPU 490-BGKB : NVIDIA(R) GeForce RTX(TM) 3070, 8GB GDDR6. Originally, the computer would turn off and have a black screen. I reflowed the onboard 32GB RAM module Chip 1 and the board started to work. After doing a system test using Dell Diagnostics, I would get the memory error message as pictured, and MemTest would throw an error with failure. Then I replaced Chip 1 with the same memory module with H5ANBG6NAMR-XNC. The MemTest error went away, and after 4 iterations of testing, there was no failure. Dell Diagnostics still says "Memory Error." I decided to take a MATS test, and it shows errors, and its report is attached. I don't understand it, but I suspect it's off by 2 bits or some bits. It's a weird error, not a specific memory chip.
    Attached is the MATS report.txt file along with PDF with all the images. Thanks!
    NVIDIA GeForce RTX 3070 Schematic & Board View
    The GeForce RTX 3070 is a high-end graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA104 graphics processor, in its GA104-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3070. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA104 graphics processor is a large chip with a die area of 392 mm² and 17,400 million...
    10-02-2024, 08:48 AM
    Thermal pad thickness for various laptop GPU / Graphics Cards
    ASUS Dual RTX 2070 OC 8GB
    ASUS ROG STRIX RTX 3080 OC
    ASUS ROG STRIX RTX 3090
    ASUS TUF Gaming RTX 3080 OC Edition
    ASUS TUF GTX 1660 S-O6G GAMING
    EVGA RTX 3060 Ti XC GAMING 8GB
    EVGA RTX 3060 XC GAMING 12GB GDDR6
    EVGA RTX 3080 FTW3 ULTRA GAMING
    EVGA RTX 3080 TI FTW3 ULTRA GAMING
    EVGA RTX 3090 XC3 ULTRA GAMING 24GB
    Gainward RTX 2080 Phoenix GS Specs
    Gainward RTX 3070 Phoenix 8GB
    Gainward RTX 3080 Ti Phoenix
    GIGABYTE AORUS RTX 3080 MASTER 10G
    02-09-2024, 08:08 AM
    NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
    The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
    10-02-2024, 08:52 AM
    NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
    The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
    10-02-2024, 07:51 AM
    NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
    The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
    10-01-2024, 01:54 PM
