Acer motherboard DA0ZR7MB8D0 showing MAINON signal short
  • Nilam
    • Mar 2021
    • 18
    • Nepal
    Dear Sirs
    symptoms is when power button pressed power LED turns on then off immediately. when i am repairing acer laptop motherboard all power are ok until i reached MAINON signal which shows short to GND which enables almost all PWM ICes .i checked it on SIO but here it also shorted to GND.
    Board details M/B part no :- DA0ZR7MB8D0
    SIO NUVOTON NPCE 781LA0DX
    laptop acer
    Kindly help me .
    Nilam
  • mon2
    • Dec 2019
    • 14618
    Re: Acer motherboard DA0ZR7MB8D0 showing MAINON signal short
    Remove all power. Meter in lowest resistance scale.
    What is the resistance to ground of MAINON ?
    Link or post the schematic of this logic board if on this forum.
    • Nilam
      • Mar 2021
      • 18
      • Nepal
      SIO pin 12 is MAINON which has impedence of 0.000 ohm.
      Does it mean sio is short ?
      • Nilam
        • Mar 2021
        • 18
        • Nepal
        Schematic ..
        • mon2
          • Dec 2019
          • 14618
          Let us confirm if the reading is correct.
          Can you post a picture of your meter on the scale used for this measurement ?
          Is your meter with different resistance scales or is AUTO style ?
          When you short the meter leads together, what is the resistance reading ? Is it the same as when you performed this measurement ?
          Some meter models will show '1' or 'OL' for over limit status. Then you must switch the meter scale to a higher value to check the proper measurement.
          Also, very important - you must remove ALL power when performing resistance checks. After all this, if you really have 0 ohms to ground resistance then yes, that is a pure short.
          • Nilam
            • Mar 2021
            • 18
            • Nepal
            Thanks for the reply.
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
              09-06-2024, 05:27 AM
            • 2Stupid4U
              Acer Nitro 5 An517-51 mainboard short circuit - Boomer needs help
              by 2Stupid4U
              Laptop data:
              NTB Acer An517-51 FHD
              i7-9750H
              16GB replaced with RAM Crucial Ballistix SODIMM DDR4-3200 32GB K2 SW
              1TB SSD
              RTX2060
              Bon soir dear online techies, enthusiasts, modest helpers and whomever I might have forgotten!
              Search gave me no hits so this is my first post.
              My Acer 5 Nitro mainboard had a short circuit when I tried to plugin a USB device. Some smoke rose from the port and it became super hot a that point of entry/exit. Warranty was of about a month.
              Since I am on a low budget I cannot afford to buy...
              08-29-2023, 01:03 AM
              Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
              This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-07-2024, 05:00 AM
