Casper c500 shuts down while booting
  • Kitayu
    • Oct 2021
    • 22
    • Turkey
    The bios of the device crashed, when the ec bios is thrown, it opens properly and enters the bios menu, but when I insert any boot device (harddisk or usb), it shuts down and does not boot. when i unplug it and plug it in it turns on again but does the same thing
    mainbord : d15d rev 2.1
  • tahahey
    casper C500 D15S 08N1-18Y2Q00 REV 2.0
    by tahahey
    Bios Dump Need Please Help
    casper c500 D15S 08N1-18Y2Q00 REV 2.0
    cpu: i5 6200u
    gpu: gt940
    Thanks in Advance
    The attached Bios bin was the original BIOS...
    03-06-2023, 05:42 AM
  • sorrowfulfloyd
    Casper MT55INP1.V.01 Laptop immediately shuts down after power button is pressed
    by sorrowfulfloyd
    Hey all,
    Just got a no name motherboard for a repair belonging to a Turkish laptop manufacturer called Casper.
    Well as you might guess no schematics available at all.
    Motherboard is: MT55INP1.V.01
    So the 19v comes in ok, 3v and 5v standby is ok, power button has 5v. I draws 0.004 amps from the bench psu, when I press the power button it jumps to 0.040, led comes on then in a blink of an eye it just shuts down 0 amps, no fan spin, nothing. I try again nothing seems to come on ONLY after I remove the DC cable and put it back again, then it's the...
    06-07-2022, 09:44 AM
  • mrtglm
    Casper Excalibur G870 DANLXAMBCC0 bios help
    by mrtglm
    Casper excalibur g870
    anakart kodu : DANLXBAMBCC0 REV C
    NLXA
    SERİ NO : SR002988186
    No image, please clean the area or install a working bios...
    10-08-2025, 05:42 AM
  • Aeisens
    Samsung UE50RU7170 not booting /no picture
    by Aeisens
    Dear all,
    My issue is the following:
    Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
    I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
    Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
    Question 1: Where should I start to...
    06-24-2025, 03:07 PM
  • Daniel Kubica
    Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
    by Daniel Kubica
    I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
    I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
    06-14-2025, 09:24 AM
