Dell Latitude 5590 ,strange behavior
  • kokono
    • Jun 2018
    • 203
    I got this board by melting pu613 IC.
    I replaced it. Before that, I checked all the voltage rails. There was no short circuit. I also tested the CPU (PL610 , PL613 about 3.5 Ohm ,PL612 4.2 Ohm).
    Currently, after pressing the start button, the Power LED and keyboard backlight turn on and off in about half a second.
    I checked all the voltage rails, they are all present up to step S5.
    From this point on, all the voltages come after pressing the start button, but they go quickly. I didn't find any short circuit in it.
    I checked the board with a thermal camera but found nothing.
    The only suspicious thing I found is the +PWR_SRC voltage, which is about 13.5 volts. But I am not sure that it is a problem.
    i did not find the schematic of this model,but it seems to be very similar to the F391p( Dell Latitude 5290 ) model. i attached it
    Please help me troubleshoot this board.
  • mon2
    • Dec 2019
    • 14504
    Re: Dell Latitude 5590 ,strange behavior
    Remove all power. Meter in resistance mode.
    Check the resistance to ground of +PWR_SRC.
    • kokono
      • Jun 2018
      • 203
      Thx, I've done it before. about 350K ohm
      • piernov
        • Jan 2016
        • 4437
        • France
        After FDMF3035 fails, CPU will most likely be dead. Very common problem on these. Always rely on warranty when possible.
        • kokono
          • Jun 2018
          • 203
          but CPU is not short , i think 3.5 ohm is normal
          • piernov
            • Jan 2016
            • 4437
            • France
            Doesn't need to be shorted to be bad.
            • anshad
              • Nov 2010
              • 249
              Typical CPU core voltage is around 1v only (Exact value depends on the model and varies according to load via SVID). When a Mosfet shorts, it may send a pretty high voltage (PWRSRC/B+ volt) directly to the CPU. Most of the time, the CPU/SoC simply dies. I speak from my practical experience.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                13.5V on main rail is ok in this board 'coz of charging ic technology used here for narrow voltage. However, i fully agree with @piernov/anshad's view. Most likely its a dead SOC. You can try fixing the fault but it'll very likely result in no display although switching perfectly.
                • kokono
                  • Jun 2018
                  • 203
                  Many thanks to all the experts.
                  Do you know the signals that I can use to confirm the CPU failure?
                  • Danila.
                    • Apr 2021
                    • 9
                    • BELARUS => POLAND
                    What is CPU model ?
                    • Srky
                      • Jul 2022
                      • 3
                      • Croaia
                      Originally posted by Danila.
                      What is CPU model ?
                      From the picture I would say it's i7-8650u (SR3L8)
                      • Danila.
                        • Apr 2021
                        • 9
                        • BELARUS => POLAND
                        I guess it's a less than have to will be
                        • mielta
                          • Apr 2015
                          • 368
                          Hi
                          Remove coils PL610-613 and see what happend
                          • Srky
                            • Jul 2022
                            • 3
                            • Croaia
                            Has anyone been able to fix this problem without replacing the motherboard?
                            • andresi
                              • Nov 2020
                              • 153
                              • INDONESIA
                              i have problem with strange issue, before the laptop is no display, so i flash the bios then i check with keyboard its normal and capslock its response, but after i connected to screen the laptop cant boot normaly just no display and no response with capslock keyboard. i check with external monitor its good. i already change the lcd and cable flexsible, but still no display and no response anyone can help or give me some solution?
                              • Stevedb
                                Stevedb
                                • Feb 2018
                                • 624
                                • Belgium
                                Hi do you have 19v and 3,3v on screen connector? Do you got the enable for backlight? BL ON ,
                                • Magnusa2
                                  • Jul 2017
                                  • 66
                                  • India
                                  Originally posted by andresi
                                  i have problem with strange issue, before the laptop is no display, so i flash the bios then i check with keyboard its normal and capslock its response, but after i connected to screen the laptop cant boot normaly just no display and no response with capslock keyboard. I check with external monitor its good. I already change the lcd and cable flexsible, but still no display and no response anyone can help or give me some solution?
                                  i have same issue
                                  any soulution for this ?
                                  • Magnusa2
                                    • Jul 2017
                                    • 66
                                    • India
                                    You have solution ?
                                      DELL Latitude 5590 Notebook 5000 Specification for Upgrade or Repair
                                      This specification for the DELL Latitude 5590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5590 boardview and 5590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5590...
                                      09-06-2024, 12:36 PM
                                      09-06-2024, 12:13 PM
